3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Is it possible to set up a RAID 0 and RAID 1 using the same 2 drives?
If I have two 1TB drives, can I partition each one into two 500GB drives, (Labelled A1, A2, B1,B2)  then set up a RAID 0 array between A1 and B1, while having A2 be a RAID 1 backup of B1, and B2 a RAID 1 backup of A1?
Or would this Simply give me the equivalent speed of a TB Raid 1?
(From what I understand, this would be similar to RAID 5, but wouldn't require a separate RAID card.)
Oct 11, 2011. 12:21 PMlemonie says:
I just thought that you've invented a new concept:
"Redundant Array of Independent Partitions" RAIP.
L
Oct 11, 2011. 11:46 PMlemonie says:
Do you need to do this, or can one RAID configuration work for you?
L
Oct 12, 2011. 12:07 PMlemonie says:
RAID  works on actual drives, I really don't think there's a fundamental advantage to the partition idea.
If there was, you would have heard of software that RAIDs a single-drive...
L
Oct 13, 2011. 1:14 AMlemonie says:
Hmm, is the predicted speed-boost going to be significant?
L
Oct 17, 2011. 11:59 AMlemonie says:
Oh damn, I could have done a super RAID installation with my old Gigabyte-board.... but I accidentally screwdrived a SM-transistor off it.
L
Oct 19, 2011. 11:28 PMlemonie says:
You'd have to split the print-job, but the thing to do would be to have 2 printers each do every other page, like odd/even.
MS Word will surely let you do that.
L
Oct 11, 2011. 12:34 PMVyger says:
At this time as far as I know the answer is no. The reason is that the raid controller doesn't even care about the partitions. The controller treats the drive as a whole and works independently of any data on it. This is why it works for any type of partition. So, like lemonie said, no.
Just a note, if I were you I would use them in a mirrored array. If one of the drives fails, and there appears to be a high likely hood of that. then you will not loose all your data. If you put them in a stripped array and one goes bad, you loose everything on both drives. Read speeds are increased in a mirrored array but write speeds are not. However new drives are already so fast, and they cash everything for delayed writing, that you will not notice a difference for almost all applications.
Oct 11, 2011. 12:18 PMlemonie says:
The RAID controller is on the board, it manages by IDE channel. So I would say no.
L
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
