3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Is it possible to 'weld' polymorph?
I've ordered some polymorph (shape lock, friendly plastic) so I'll be able to try it myself in a few days, but I was wondering if it's possible to attach (for example) a polymorph rod to a block by heating a spot with a pen-torch and hot air attachment then pushing the rod against it?
Aug 11, 2010. 5:26 PMHobbitComedian says:
This was also a good step by step on "welding" posted by another place that sells this type of plastic: http://www.instamorph.com/?p=61
Feb 8, 2010. 12:39 PMKiteman says:
You may even be able to do it by dipping the end in boiling water, softening it, and then pressing it in place.
Feb 8, 2010. 3:20 PMRavingMadStudios says:
+1
Done it a gazillion times, and it works like a charm as long as you warm up both sides of the 'weld'.
Feb 8, 2010. 12:46 PMamando96 says:
 yes, do what kiteman says, if you use flame around polymorph it wil turn black and dirty, and wont go as well as you think.
glue the rod to the block with cianoacrilate glue(super glue) its the best glue for plastic, and smooth materials :D
Feb 8, 2010. 12:52 PMJayefuu says:
You making anything exciting Andy?
Feb 8, 2010. 11:57 AMseandogue says:
I would expect so, since you can remelt.  By weld, you do mean polymorph to polymorph, yes?  any other mating will not be a weld, and many plastics will not "stick" to prototyping plastic. Remember also that temperature is your enemy for durability...
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
