Is there a simple IC or circuit available that can do these kind of pulses?
I need a circuit that will give just a few pulses..... starting with a few seconds of "ZERO"...a long "one"... Then three quick pulses.... then end with a constant "ONE" . I have tried using a binary counter circuit and led's, but my design abilities are somewhat lacking. I don't know how to use microcontrollers so that won't help. I was hoping for some kind of IC that has input pins that can be grounded or diodes attached. Then the IC would scan those parallel pins and send out the serial pulses as described. I need this to activate another circuit at work for my boss. I am good at building electronic circuits but not so great at designing them. Thanks in advance for your help.
Visit Our Store »
Go Pro Today »
Yep, easily do-able using either parallel in, serial out (PISO) shift registers, a demultiplexer running from a binary counter or a binary counter driving a ROM.
To decide which is the best way, you'll need to tell us the exact timing sequence required, how it needs to be triggered and how it needs to be reset.
Picaxe 08 and minimal components - essentially 1 x 10K resistor to hold programming pjn low.
programme - assumes output from output 1 (leg 6)
Assumes positive trigger on pin 3
Start:
If pin3=0 then start, (check pin 3 for trigger)
High 1. (turns output on - High)
pause 2000, (waits for 2 seconds)
Low 8, (turns output off - low)
High 1
pause 500, (wait for 1/2 sec)
Low 1
pause 500, (wait 1/2 sec between pulses)
High 1
Low 1
pause 500
High 1
Low 1
pause 500
end ,(if you want it to stop now. - or goto start if you want it to repeat)
You may need to do a little reading in the FREE PDF manuals to see about interfacing, Down loading the programme with their FREE programme editor. But essentially as you describe your problem that is an answer.
