Is there a way to count button pushes on an arduino and have it reset the count at a certain number?
I would like to count the number of buttons pushed and when it reaches the number 8, I would like it to reset it to 0. Can anyone help me with an example code or a tutorial somewhere? Greatly Appreciated!
Take the button sketch. Add a counting variable. If the button is pressed add 1 to that variable. If the variable is >= 8 store 0 to the counting variable.
const int buttonPin = 2;     // the number of the pushbutton pin
const int ledPin =  13;      // the number of the LED pin
int count = 0;               // Count the button presses
// variables will change:
int buttonState = 0;         // variable for reading the pushbutton status
void setup() {
  // initialize the LED pin as an output:
  pinMode(ledPin, OUTPUT);
  // initialize the pushbutton pin as an input:
  pinMode(buttonPin, INPUT);
void loop(){
  // read the state of the pushbutton value:
  buttonState = digitalRead(buttonPin);
  // check if the pushbutton is pressed.
  // if it is, the buttonState is HIGH:
  if (buttonState == HIGH) {
    // turn LED on:
    digitalWrite(ledPin, HIGH);
    count++;               // add 1 to the count
    if (cout >= 8) {
      count = 0;
  else {
    // turn LED off:
    digitalWrite(ledPin, LOW);
hye mpilchfamily is there a wayto make the led blinking after fourth time push the button? is it possible using this coding???
Yes. Changes can be made to this code to accomplish that. Good luck with it.
i try to make a change but failed... can you help me?
Change the if count >= 8 to count >= 4. Between that and the count = 0 set led to high delay and set led low. Repeat the high low and delay as much as you want.
like this?
if (buttonState ==LOW) {
// turn LED on:
if (count >= 4) {
delay(500);
count = 0;
Have you tried to run it? Try it for yourself and see what happens.
i have try it before actually.. and led blink when i pressed button once...not after the fouth time... (i used sound sensor as input)
Cause you need to check your notation. Your missing a }. So the arduino reads the if count statement and then executes the flash and count reset no matter what.
// turn LED on:
if (count >= 4) {
delay(500);
count = 0;
sorry for that sir.. i have put the missing { on the coding.. but i dont know what the cause.... led still blink when button pressed once.. not after the fourth time...
void loop(){
if (buttonState == LOW) {
// turn LED on:
if (count >= 4) {
digitalWrite(ledPin,HIGH);
delay(500);
digitalWrite(ledPin,LOW);
else {
// turn LED off:
PatelA238 months ago
how can i see ... how many time push button are pushed ????
AzamJ1 year ago
hye guys how to make the led blinking after fourth time push the button? is it possible using this coding???
    // turn LED on:
    if (cout >= 8) {
      count = 0;
   while(buttonState==HIGH); //wait here.
bigjohn412 (author) 4 years ago
Ok, I understand now. Thanks!
Careful, that sketch has a fatal flaw.
How many iterations of loop() happen while the button is pressed?
1000 ?
Yep...
count ++
And...
if (count >= 8 ) {
Missing a space between count and the ++. Also forgot the 'n' in count on the if statement. Should have proof read and compiled the sketch before posting.
There are many ways to structure it depending on the exact needs for the sketch. But you get the general idea of adding a means of tracking things. Create the variable for tracking, add to the variable where needed and form time to time query that variable to see if it's reached the mark you want.
You need a state to catch the fact the button STAYS pressed. What you want to count is the state off-on-off
