Is there a way to lengthen the plastic blade of the basic toy lightsabers (about 12 dollars)?
 I like how this particular model retracts all the way into the hilt, but the blade is very short, and in conjunction with my stature it seems even shorter. Holding the toy up to the light I can see that there is a lot of plastic that is behind the other pieces. Is there a way to utilize this and make the blade longer?
1 answer
May 24, 2010. 4:01 AMRavingMadStudios says:
In theory, you could take the blade apart and very carefully sand down the areas that overlap, allowing the sections to extend further before stopping.  Use a very fine sandpaper, and test-fit frequently to avoid removing too much material and having the whole thing fall apart.
In practice, I doubt you would gain enough length to make it worth the trouble, but I've never actually tried it, so what do I know?.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
