Is there a way to lower a photocell's resistance to amps?
I am making a device which uses a laser to lower a photocell's resistance to the point where enough current can flow to begin spinning a motor. Unfortunately, the motor (4.5 V) starts off by drawing about .75 amps and once running falls to .25 amps, but apparently the photocell can only draw a lot less- the only word I've been able to find is that it typically draws about 1 milliamp, which is nowhere near enough. I have two questions- first off, does anyone know how many milliamps I can run through a photocell, and is there any way that is pretty cheap so that I can lower the amps drawn or the resistance of the photocell without stopping the motors?
kelseymh5 years ago
Use the photocell to trigger a relay.
Perfect solution.
seraine (author)  Re-design5 years ago
That's what I was thinking, but I haven't really used relays and I have no clue as to what kind I'd use or how I'd do it. Any ideas?
Well, you need a relay which can handle 1A at 5V (to allow for overages) on the output. For the photocell, you need the relay's input to trigger at a few mA, at whatever voltage you've got across the photocell. Search on Digikey, or Mouser, or Jameco, for a relay with those parameters.
seraine (author)  kelseymh5 years ago
I went on jameco, and from what I know I think that one of these two would do the job: http://www.jameco.com/webapp/wcs/stores/servlet/Product_10001_10001_187240_-1 or http://www.jameco.com/webapp/wcs/stores/servlet/Product_10001_10001_174450_-1 .
Or an appropriate transistor.
L
iceng5 years ago
I have a TO-3 size ( cadmium sulfide ) 1.5Amp photo resistor
not available any more and that would be a sledgehammer way
to run your motor.
The photo resistors reasonably available to you are in the millamp range so you need a device that can control your motor with a limited
current sensitive photo resistor.
A sensitive relay is the best way to go to run your motor on / off.
Or an op-amp if you want speed control.
Or a micro processor if you want more sophistication.
You need to select a std battery voltage before any circuit designs
can be suggested.
( 3 AA cells deliver 4.5VDC ) not very good for relays or for op-amps.
There are low current coil relays that work on 5v that could run your
motor but you will need a higher current photo resistor
see the pictures
Otherwise you will need a transistor amplifier before the relay,
Anyway this problem is electronic engineering with what you have
and what you can get.
kelseymh gave you good advice but I sense that  you need more, like
some body to design this just for your application.
A
