Is there a way to make a diy surround system?
remember, this is for a computer
marcdraco7 years ago
There are several depending on how the source material is encoded. The simplest (now largely defunct method) encoded the rear channels on the front pair and used a differential amp to "decode" the rear signal into a single mono channel. This is also called Dolby Stereo after its inventor.
Modern systems use 5.1 or 7.1 which is encoded digitally and has to be decoded by the same system.
Sparkington is correct - DIY is going to be very expensive. A simple (functional card) can be had for a desktop for a few tens of bucks. Soundblaster and others make some excellent units including ones that can utiliise USB so you can fit them to a laptop.
With most of these, you'll also need a discrete amplifier and speakers to make it all work. The subwoofer is the most important for most of us - that's what makes the sound sound LOUD! The other channels give our brains directional queues and the speakers don't need to be so good (or large) for gaming.
Redrockers8 years ago
um... hook up loads of speakers and put them all round you
Sandisk1duo8 years ago
you'll have to buy it
Sparkington8 years ago
Diy surround system yep there an easy way doing this, it call a surround system card for computer. It would cost less buying one than making one, I have seen a circuit once, it was complex and heaps of parts. So easy buying one than making one.
