loading
Is there a way to make an air compressor that plugs into the wall run off of alkaline batteries?
Sandisk1duo7 years ago
don't run it on alkiline batteries, instead get yourself a nice sealed lead acid battery, it costs about the same amount, and the lead-acid battery is rechargeable most lead-acid batteries are 12v, so you can hook up a small compressor to it
CapnTac (author) 7 years ago
Thank you for your time. I no longer require an answer to this question. However, I would really like to thank lemonie for his patience with me. I know for a fact that I would never be that patient with a nooblet.
lemonie7 years ago
Yes, but what are the specifications / technical details of the compressor? L
CapnTac (author)  lemonie7 years ago
What do you mean by that question? I'm sorry, I'm a novice when it comes to electronics. The hardest thing I've ever done is hook lights and 9volts up and things like that.
lemonie CapnTac7 years ago
I meant what power supply does it currently run off, V, A? L
Let me explain this better. I'm working on a design for an airsoft MMG, and the design calls for an air compressor. I simply wanted to know if there was a cost effective way of hooking up my old one to some batteries before I run out and simply buy one that was intended to run off of batteries, but I'm leaning towards the latter at this point.
theRIAA7 years ago
yep. just connect 100 AA batteries together, end to end, and hook the ens to the plug.
SInce he says "plugs into the wall", 150V DC ain't going to do the compressor anygood.... Or the batteries ;-) Steve
