3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Is there a way to make an ultrasound-to-sound "audio spotlight" DIY?
http://en.wikipedia.org/wiki/Sound_from_ultrasound
The Holosonics Audio Spot Light sells for $2,500, and the competing Sennhieser AudioBeam sells for $4,500.
Is it possible to do something like this home-made?
Mar 4, 2012. 4:36 PMdragonbtv says:
I'd like to make a test from smaller transducers units.
But, before that, any comments about the harmfulness of heavy ultrasound wave, any US standard?
It looks like the "audiosportlight from Holosonics" did neither mention the harm nor warning of their products.
Mar 8, 2011. 8:18 PM7heaven says:
someone already did it!
http://zao.jp/radio/parametric/index_e.php
Nov 30, 2010. 11:58 AMmoose224466 says:
It works by using tartini tones, or also called combination tones........so if you have a transducer producing 200,000 hz along with 200,700 hz there is a third tone that can be herd which is 700 hz..... aka the difference........
Apr 20, 2009. 5:35 PMDELETED_GuardianFox says:
Yes, it's possible. The parts are readily available... BUT... I haven't found out yet exactly HOW they accomplish what they do. Yes it's a transducer spitting out sound in the ultrasonic-frequency range... but how does the controller know how to modulate that ultrasonic frequency so that it vibrates the air in JUST the right way to create audible sound?
Apr 29, 2009. 12:16 PMDELETED_GuardianFox says:
No offense, but that's not explaining how they modulate the "beam." What formulae are used to translate from one form to the other, accuratly?
Aug 17, 2010. 6:57 AMroy44 says:
The smaller one is $1999 retail, which is a bit cheaper, but they might have cheaper units if you ask. But from what I know the ultrasound transducers are not cheap! ($2-$3 each, and you need a LOT of them). (The Sennheiser link is broken.)
There isn't much specific information about modulation on the Audio Spotlight website, but there is a page describing why a phased array can't make directional sound:
http://holosonics.com/tech_directivity.html
I don't know what all this "teeth and bone" stuff is, though.
Aug 6, 2010. 8:37 PMHSOONG says:
Forget about all the myth said in the web these days! How can you contain the sound within a small area and why need an array of transducer to contain it. The orginal web info had been altered long ago. Forget about all the ultrasound convert into sound stuff, if it is even true. The secrete is " your teeth and maybe the bone near it" which will act as transducer in converting ultrasound to bone transmitting sound directly to you ears no AC5.1, mono only sorry.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
