loading
Is there a way to "rename" my hard drive so the computer thinks its a different letter?
To be more specific. I need to "rename" the "C" drive (alternate hard drive) to think its the "D" drive (currently the 'core' of my OS) Is this possible?
XOIIO7 years ago
This link should help you: Support.microsoft.com/kb307844 It has how to change the drive names, and much more information. Hope I helped!
B.F.L.M (author)  XOIIO7 years ago
unfortunately this wont work, this method does not allow you to change the path of the Main partion of windows. (the D drive is my main partion and i want to call it C which is partioned to a different OS (untill i format it) so this is gonna taking some "hacking" i belive...
XOIIO B.F.L.M7 years ago
Well, the best of luck for you. If this is the case it seems even an open source is would need to be "hacked". Let me know if this works out for you, I may want to try it...
roger that dude, thanks for the help
Jayefuu7 years ago
In Windows: control panel -> Administrative Tools -> Computer Management -> Disk Management That is where you can swap around drive letters. I don't know if it will let you change the name of the boot drive though. I doubt it.
B.F.L.M (author)  Jayefuu7 years ago
Yeah, it says you cant modify the 'boot' or 'system' drive :(
lemonie B.F.L.M7 years ago
Like the plumber says, it should be easy enough to boot onto the XP partition (it's the same physical drive?). Hitting some button as it boots I think, or booting it off the Windows disk? L
plumber_bob7 years ago
You can also set it up in your system bios. I have to do this as my boot drive would be drive D: if I didn't, and it wouldn't boot up. Also this can be used to switch operating systems, on the same computer, it's kinda like having 2 p.c.'s in one!
B.F.L.M (author)  plumber_bob7 years ago
yeah i know, im running Windows 95 and Widows XP. 95 is on the C drive but probably unuseable as a formated most of the drive. I plan to get rid of it, because the D drive is smaller so if i can make my D drive the C drive, then i can create a ghost of it and put it on the C drive (hopefully)
