Is there an easy and safe way to trim/grind the edge of a glass plate?
I'm trying to fit a pre-cut mirror glass (rescued from a $5 Wal-Mart mirror) into the back of a shadow box.  The mirror itself is not quite square, so there is one corner and part of the adjacent edge which won't quite fit into box (about 0.5 mm overlap).  If this was wood or plastic, I'd grab some sandpaper and bring the edge down to fit.  Is there an equivalently easy, but safe, method for doing the same with glass (3 mm thick)?
Mar 21, 2013. 1:47 PMKiteman says:
I'd just put my goggles on and then have at it with a dremel grinding bit, or even just a piece of carborundum paper.
It worked fine on the tubes of my "4am glass robot".
Mar 21, 2013. 2:59 PMKiteman says:
(You're welcome.)
Mar 21, 2013. 1:12 PMsteveastrouk says:
Diamond cut-off wheel for an angle grinder, running wet ? ANy friends with lapidary saws (thin diamond blades) ??
1/2mm will take an age to sand off
Mar 21, 2013. 1:41 PMsteveastrouk says:
Safe: see if they'll run wet or at least lubricated. Otherwise overheating might crack the glass.
Mar 21, 2013. 5:12 PMfrollard says:
glass wet-sands very nicely; I'd be extra careful about safety glasses AND a respirator; glass dust in your lungs is just as bad as your eyes :) Glad it worked!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
