Is there any official theme that doesnt slow windows xp down?
8
answers
Answer it!
There are some other things you can do to speed up your machine, and some may even allow you to keep Royal Noir.
-Turn off some of windows' animations and effects.
-Disable a few unnecessary services.
-Disable any and all unnecessary startup programs.
-Upgrade your RAM.
If none of that helps, you can try these measures to get a smoother system.
-Switch to "Windows Classic Style" and disable all remaining effects. It'll look like Windows 98, but it'll run faster.
-Try Ubuntu (or Netbook Remix) or some other Linux flavor designed for lightweight systems. I highly recommend Ubuntu and Puppy Linux for beginners and Slax for Intermediate users. These will all run well on most Netbooks and should have enough free resources to handle some nice themes.
http://www.ubuntu.org
http://www.ubuntu.com/getubuntu/download-netbook
http://puppylinux.org/main/index.php?file=Overview%20and%20Getting%20Started.htm
http://www.slax.org/build.php
Switch to a lighter Antivirus.
Avast! is great and free, but it's too heavy for most netbooks. Norton is notorious for bogging down even the most powerful machines.
Right now, the free Microsoft Security Essentials is my choice for use on netbooks. It's light enough and still able to do it's job.
-> But concernin the "slow problem":
1. Get sum "XPAntispy" (freeware) from the net. It's meant to do sum changes on XP, you normally can't do, say it speeds up the sys and cleans it from implemented adware and related crap; XPAntispy is kept in devellopment and by now they added sum tweaks.
2. And sumtimes it might be of sense, if you get sum "Regcleaner" (freeware), a small program that cleans up the sys' registry as programs that get uninstalled often leave sum entries in the registry, which means that cache is reserved for already dead programs.
Just install it and under "Options->Registry Cleanup->Method" set it on Automatic and to run the scan go under "tools->Registry Cleanup->Do them all". For me it's always been amazin to run that prog on comps of the elder generation and other "noobs" as it always gets new highscores of found and killed dead entries.
3. Sumtimes defragmentation of the hard disks speeds things up. The MS-defrag is crap. Best seems to be O&O defrag.
-> You can also just get a pack of such progs, e.g. TuneUp Utilities, but i dun like them that much as i never know what they are doin rite the way i start em.
