loading
Is there any water soluble powder that when compressed into a form, stays that way?
Basically what the title says, I need it for an experiment.
Mix nearly any fine powder with a little starch powder and it will "tablet". We've pelletised glass powders like that.
Zem (author)  steveastrouk7 years ago
Corn startch? Or just startch?
either.
orksecurity7 years ago
Soap?
I think we need to know more about what you're trying to construct, what it has to stand up to while solid, and how quickly you want it to dissolve. After all, _iron_ will dissolve if you give it enough time...
Zem (author)  orksecurity7 years ago
I'm trying to get baking soda to compress into little tablets... But it wouldn't work, so I asked the question above
try corn starch ,  that was th' original medium for making medicine into pills
Re-design7 years ago
Hydro-stone much stronger and long lasting than plaster of paris.
 Plaster of Paris
 Clay
x-actly (I came back to the thread just to add those two, but you beat me to it....)
seandogue7 years ago
Portland cement
lemonie7 years ago
Several tonnes will compress a lot of powders into lumps. Dampening them helps, but I reckon steve has a good answer on this.
L
I thought that pressure was all you needed, until trying to compress glass powders. My grandfather was a pharmacist, and my dad remembered the "magic ingredient"
It depends upon what it is. Potassium bromide for example will press into transparent disks (~10 tonnes per square cm), glass I wouldn't expect. But ye-olde pharacutical preparations are obviously tried & tested - a good answer.
L
lemonie lemonie7 years ago
Although I may be out on the pressure, the gauge did read 10 tonnes, but I'm not too sure after that.
L
Kiteman7 years ago
Sugar
Salt
Baking powder
Poster paint...
...just about any powder can be pressed into solid blocks with enough pressure.
Koosie7 years ago
Do you mean that you want a thing to dissolve when it goes in water?
I don't know about one powder but you can try: https://www.instructables.com/id/How-To-Make-Bath-Bombs/
Try fiddling with the ingredients/mixtures, maybe you can get something close to what you want.
Hope it helps.
