Is there any way to amplify a smell without altering it?
I need to find a way to make a weak smell stronger without using things like fans. The smell is good but you can't smell it unless you put it right under your nose.
Is there any chemical or something that can do this?
Thanks.
EDIT- the smell in question is deodorant.
5
answers
Answer it!
There may be chemicals which would alter how the receptors respond, but I'd be leery of mucking about with them... not least because they would make everything else smell odd until they wear off.
Usually, it's better to concentrate the smell at the source -- use a larger or more concentrated sample, or heat it so more of the scent is released.
I'm assuming that you've already checked that whatever-it-is is safe.
But we don't know what you're smelly-stuff is yet.
L
