Is there any way to reset or an inside fuse to change on a TomTom navigation device? GPS 300?
answers
Answer it!
The charge controller and/or dc-dc converter has probably failed.
It could be a chip about 5mm x 5mm with about 24 pins UNDERNEATH it (must be soldered with hot-air)
Or it could be 3 chips about 2mm x 2mm with 8 pins each.
Ask someone who repairs these.....
Dissemble it, connect the power, using a voltmeter check from the power input, keep following the tracks till you receive 0V on the voltmeter. It will be this component that will need replacing
Steve
