Is there anyway that someone could make me a .hex file from this .asm, or at least tell me how?
Hey, I have a .asm file. I have tried MPLAB, but I am not doing it right.
; BINCLOCK.ASM A clock that displays in bcd numbers ;
        LIST P=16F84 ; tells which processor is used
        INCLUDE "p16f84.inc" ; defines various registers etc. Look it over.
        ERRORLEVEL -224 ; supress annoying message because of tris
        __CONFIG _PWRTE_ON & _LP_OSC & _WDT_OFF ; configuration switches
            CBLOCK 0CH
                sec ; seconds digit
                sec10 ; 10's of second digit
                mins ; minutes digit
                min10 ; 10's of minutes digit
                hr ; hours digit
                hr10 ; 10's of hours digit
                w_temp ; holds W during interrupt
                status_temp ; holds STATUS during interrupt
                fsr_temp ; holds FSR during interrupt
                button ; holds mask for pushbuttons
              ENDC
; Here are some DEFINEs which give 'names' to pushbutton port bits ;
            #DEFINE SETPB PORTB, 4
            #DEFINE SELECTPB PORTB, 5
            #DEFINE SHOWPB PORTB, 6
            ORG 0 ; start at location 0
            goto main ; jump over to main routine
ORG 4
goto isr ; jump to interrupt routine
; High limit + 1 of digits at position W ;
sethi:
addwf PCL, f
dt H'A',H'6',H'A',H'6',H'A',H'3'
; Delay routines ;
msec250: ; enter here to delay for 250 milliseconds
movlw D'250'
nmsec: ; delay for # msec in W on entry
nop ; each nop is 0.122 milliseconds
nop
nop ; each total loop is 8 X 0.122 = 0.976 msec
nop
addlw H'FF' ; same as subtracting 1 from W
btfss STATUS, Z ; skip if result is zero
goto nmsec ; this is 2 X 0.122 msec
return ; back to calling point
; Delay for one second ;
onesecond: ; a subroutine that delays for 1 seconds
call msec250
call msec250
call msec250
call msec250
return
; Put value in W on LEDs for 1 second ;
sendnbr:
movwf PORTB ; light LEDs
call onesecond ; wait 1 second
clrf PORTB ; clear the LEDs
movlw D'100' ; pause for 0.1 sec
call nmsec
return
; Send the current time out LEDs ;
disptime:
movf hr10, W
call sendnbr
movf hr, W
call sendnbr
movf min10, W
call sendnbr
movf mins, W
call sendnbr
return
; Wait until selected button is released ;
waitup6: ; wait for show pushbutton up
movlw B'01000000' ; RB6 mask
movwf button
goto wait
waitup5: ; wait for select pushbutton up
movlw B'00100000' ; RB5 mask
movwf button
goto wait
waitup4: ; wait for set pushbutton up
movlw B'00010000' ; RB4 mask
movwf button
wait:
movf button, W ; mask into W
andwf PORTB, W
btfsc STATUS, Z ; skip if not zero (released)
goto wait
movlw D'10'
call nmsec ; wait 10 msec for debounce
movf button, W ; check for release again
andwf PORTB, W
btfsc STATUS, Z ; skip if selected button released
goto wait
return ; yes, finished
; Initilization Subroutine ;
init:
movlw B'0000000' ; all outputs port A
tris PORTA
movlw B'01110000' ; RB4 - RB6 inputs, others outputs
tris PORTB ; on port B
movlw H'0' ; all low (off)
movlw PORTB
movlw B'00000100' ; pull-ups enabled
; prescaler assigned to TMR0
; prescaler set to 1:32
; rolls over each second
option
movlw 0
movwf hr10
movlw H'9' ; initialize hrs, mins and secs
movwf hr ; Do this before interrupts are
movlw H'5' ; turned on because isr also acts
movwf min10 ; on these registers
movlw H'0'
movwf mins
movwf sec10
movwf sec
movlw B'10100000' ; GIE & T0IE set, T0IF cleared
movwf INTCON
return
; Interrupt routine, increments time by one second (BCD) ;
isr:
movwf w_temp ; save W
swapf STATUS,W ; save status
movwf status_temp ; without changing flags
swapf FSR,W ; save FSR
movwf fsr_temp ; without changing flags
movlw sec ; point at sec register
movwf FSR
newdigit: incf INDF, f ; current digit up one
movlw sec ; get difference between sec and FSR
subwf FSR, W
call sethi ; use to get high limit + 1
subwf INDF, W ; reached that number yet?
btfss STATUS, Z ; skip over if yes
goto restore ; else exit isr
clrf INDF ; set current digit to 0
incf FSR, f ; point at next digit
btfss hr10, 1 ; has hr10 reached 2?
goto newdigit ; no, increment the next digit
btfss hr, 2 ; has hr reached 4?
goto newdigit ; no
clrf hr ; yes, set hour to 00
clrf hr10 ; and hour 10
restore:
swapf status_temp,W ; get original status back
movwf STATUS ; into status register
swapf fsr_temp,W ; get original fsr back
movwf FSR ; into status register
swapf w_temp,f ; old no flags trick again
swapf w_temp,W ; to restore W
bcf INTCON,T0IF ; clear the TMR0 interrupt flag
retfie ; finished reset GIE
; Increment and display digit pointed to by FSR ;
updigit:
incf INDF, f ; selected digit up one
movlw mins ; set up to subtract mins address
subwf FSR, W ; from address of current digit
call sethi ; get maximum of digit + 1 into W
subwf INDF, W ; is it = to current digit value?
btfsc STATUS, Z ; gives zero if yes, skip if no
clrf INDF ; reset value of digit to zero
movf INDF, W ; get current value and ..
movwf PORTB ; display it
call onesecond ; pause for 1 second
return
; increment selected digit until select pressed ;
setdigit:
movwf PORTB
btfss SETPB ; set pressed?
call updigit ; yes
btfsc SELECTPB ; check if select pressed
goto $ -3 ; repeat till select pressed again
call waitup5 ; make sure select released
incf FSR, f
return
; Select and increment digits ;
select:
bcf INTCON, GIE ; no interrupts while setting time
movlw mins ; point at minutes register
movwf FSR
call waitup5 ; wait on select pushbutton up
movlw B'00000001' ; light right LED (mins)
call setdigit
movlw B'00000010' ; light min10 LED
call setdigit
movlw B'00000100' ; light hr LED
call setdigit
movlw B'00001000' ; hr10 LED on
call setdigit
clrf PORTB ; clear LEDs
bsf INTCON, GIE ; enable interrupts again
return
; The main routine ;
main:
call init ; set up initial conditions
loop:
btfss SHOWPB ; check for show pushbutton
call disptime ; display the time
btfss SELECTPB ; check for select
call select
goto loop ; do forever
end
Better to learn how to do it yourself. What errors do you get when you try and assemble this code ?
Steve
16zzundel5 (author)  steveastrouk6 years ago
Actually, I got it to work. Thanks anyway!
