3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Is this a fuse or a resistor?
I have been having difficulties with a PSU construction for a formerly battery driven (unknown amperage, 18 v ) electric drill and first needed help in identifying a part; picture included:
Nov 13, 2011. 8:25 PMiceng says:
The very clean laser cut not all the way around a ceramic base strongly suggest a resistive element.   I do not recognize the edge of the laser cut weather metal or resistive material it could be obscured by the laser burn.
I am familiar with fuses clear like colorex shows and smaller opaque ones.
In the final decision, I vote a power resistor
Always learning is my stupid goal because when I attain the most knowledge and experience I will die !
A
Nov 14, 2011. 6:12 AMgmoon says:
It could be either. It does look a lot like a wire-wound power resistor (but somewhat like a fuse, too).
Can you test it properly, in situ? If not, desolder one leg and meter it.
Nov 14, 2011. 2:41 PMgmoon says:
Correction--it's very LOW resistance. ;-)
Nov 15, 2011. 6:18 PMgmoon says:
I dunno about the meter--sometimes the digital ones are a little funky. Digital meters also have accuracy problems reading low resistance--even on the lowest setting (which you should be using, maybe that's part of the problem). That's due to the accuracy factor--if the meter accuracy is 2%, but the scale is 0-200 ohms, that's a potential error of 4 ohms (2% of 200)--a huge amount when you're checking a 1 ohm resistor.
It should read somewhere between 0 and a small ohm value (like 1 to 10 ohms). That's also consistent with heat--a low value resistor passes lots of current, so it gets hot. Consequently it's large and beefy so it won't fail. It's also a consistent value for a resistor meant to limit current in a motor.
I'm not sure why it's there--but I'm not very knowledgeable about motors personally. Maybe it's there to limit current and prevent damage to the batteries (or the motor?) if the motor is switched on when it's being mechanically prevented from rotating...
A fuse? It wouldn't show much resistance either if it were whole. A fuse shouldn't be very hot on the exterior, unlike a power resistor. It would be infinitely high resistance if it were blown, but it couldn't get hot either.
A very high value resistor would pass very little current, and be closer to an open circuit.
Nov 16, 2011. 10:48 AMgmoon says:
Danger! Long reply ahead...
Sorry, gh, I really don't know why your meter reads like that. You're sure there's no other components; i.e., another current path when you test it, right?
Not a dumb question; not argumentative. Two ways to look at the resistance / heat thing--one is (sorta) logical, the other is mathematical.
Logically, if greater resistance == more heat, then an open connection (air!) is VERY high resistance, and would be the hottest of all. That's clearly not the case. You need current to flow to generate heat.
But wait...a very efficient conductor (thick wire) with low resistance (and lots of current flow) doesn't generate much of heat, either. So why does a resistance value that's seemingly midway between the two generate heat?
OK, turning to math. You really need to look at more than one Ohm's Law equation to make sense of it...
First, remember that current is the the same for all series components--if a motor draws 0.5 amps, then a resistor in series also draws the same amount of current, 0.5 amps.
So:
P = I2 X R (watts = amperes squared X ohms)
If a motor draws .5 amps, and the connecting wire is 0.005 ohms:
Power = 0.00125 watts
Not much heat...
If a motor draws .5 amps, with a series resistor of 5 ohms:
Power = 1.25  watts
Lots more heat!
So let's get ridiculous:
If a motor draws .5 amps, with a series resistance of 100000 ohms:
Power = 25000  watts!
HUGE AMOUNT OF HEAT! LITERALLY Unbelievable!
What's wrong with that last scenario?
Volts = watts / amps
25000 / 0.5 = 50000 volts
You'd need 50000 volts to "push" 0.5 amps through a 100000 ohm resistor. That's the missing link here... We're forgetting the Ohm's Law interaction between current, resistance and voltage. You push enough current (by upping the voltage)--then yeah, a larger resistance will convert all that to heat. IF you could find a power resistor with a value of 100K (hint: you MIGHT find something like that at a power station).
Yeah--with enough voltage we can even overcome an open connection and generate massive amounts of heat (think lightning!).
So by raising the series resistance, the voltage needs to increase to maintain the current draw.
Obviously, there's a practical "sweet spot" for motors & series resistors, based on their current draw, their inductive load (in ohms) and the supply voltage (and the size / wattage rating of the resistor). If I were to guess the load resistance of the drill, something like 10-20 ohms would seem reasonable. I call that a "low impedance" device!
So any series resistance will be smaller that than that (10% ? 15% ?), or the voltage that would be needed to "push" the current would quickly rise to an impractical level...
Nov 17, 2011. 6:07 AMgmoon says:
I probably should have summarized the "lecture" more simply:
For most practical circuits, the voltage and the load are fixed. So increasing the series resistance increases waste heat. But only up to a point. Beyond that point the series resistance limits the current, and the heat as well.
Hey, I've just picked things up over the years as a DIY hobbyist, too--and for most of those years, didn't use the math either.
I learn best with practical examples--and better by far when it's an immediate problem I'm trying to solve.
You can still cull some cool info from your drill project, just with the tools on hand:
-- Measure the current draw of the motor (ammeter in series), both turning freely and also under a mechanical load.
-- If the power resistor is in series, there will be a voltage drop (over both). Take a voltage reading across the motor itself. Try that when the motor is working hard, too.
From those two facts (volt, amps) you'll be able to find the real "load resistance" of the motor (in ohms) using Ohms Law. Finding the load via math is more accurate than measuring resistance directly--the motor is an inductor, not a resistor. Also, it will probably change it's load when it's "doing work," and at different speeds, too.
Ohms = volts / amps
-- Measure the voltage over the resistor, too.
From the examples in my (loooong) post above, it should be plain that two devices in series DO draw identical current, but DON'T consume the same amount of power. You can work that out, too.
You might not NEED to know this for your project, but understanding stuff like this opened up a new world for me...
Nov 18, 2011. 4:58 AMgmoon says:
Yes, you may need to lift one end of the resistor to get an accurate reading...
Mathematically I have no chance of understanding advanced physics ;-). But the high school-ish level stuff is still great. Also, I had a class in college where the prof showed us how Einstein used basic equations to arrive at his conclusions regarding time dilation. Fantastic.
I had great satisfaction converting my little "radio tube" amp filaments from AC to DC. Due to the voltage increase that comes with rectification, I needed a new series resistor value. I outlined it here on my ible; it's a very similar exercise to our above discussion. All thanks to Ohms Laws.
Just set yourself a practical problem--you'll solve it, I'm certain.
(I do have an old textbook on "introductory circuit analysis." Never took a class, but it's a good reference.)
Nov 21, 2011. 6:06 AMgmoon says:
OK, resistor confirmed.
It must be there for a reason--can you trace/draw a schematic of the whole shebang? We don't really know if it's part of the charging, control, or has another purpose...
Nov 22, 2011. 5:08 AMgmoon says:
Hope you didn't fry anything else when you reversed the polarity...
It would be interesting to see a schematic. I'm not super conversant with motor stuff, and would like to learn more.
Nov 22, 2011. 7:40 AMgmoon says:
Is the PCB actually the battery charger for the drill? Somehow I assumed it was part of the drill itself. But the LEDs would contradict that.
If so, I wonder if the power resistor is there to prevent the battery from overheating. A drained battery would draw considerable current, and could be damaged without current limiting.
Nov 22, 2011. 8:53 PMgmoon says:
Just a thought--a battery-charging circuit might not be the best power supply for actually running the motor... :-)
Nov 23, 2011. 8:11 AMgmoon says:
I bet you have all the hardware you need to (re)design a viable power supply...assuming the transformer, etc. can handle the current draw of the motor.
Nov 14, 2011. 11:52 AMlemonie says:
Apply the multimeter to it.
I think it may be a heavy-duty-resistor, which has been fine-tuned by cutting that groove (conductive on the outside, they're usually covered in paint)
L
Nov 14, 2011. 10:03 PMlemonie says:
It's a low-value resistor.
L
Nov 15, 2011. 11:31 PMlemonie says:
How does it get hot if it isn't a conductor?(I don't get that)
L
Nov 14, 2011. 3:26 PMiceng says:
Still would be interesting to see the solder side.
There are semiconductor ( I think called polyfuses ) that are both a resistor
and a fuse and reset after switched off and also can be damaged.
Nov 14, 2011. 7:18 PMelectfire says:
Hmm looks similar to those cylindrical house fuses...once you peel the labeling sticker off.... The end caps definitively in my opinion give it away... I have yet to see any resistor with end caps like that... I think that it might have originally been a fuse that was designed to be put in a fuse holder on the board, but the manufacture decided to cut cost by just soldering it directly to the board...
I agree with Wesley666, I would check the location of where the part is in reference to where the power comes in...
If you intend on reusing the board I would (once it is identified for sure as a fuse) replace it and add in a fuse holder,not only would it make it easier if it blows, but I personally think it would make it a bit safer, as I personally wouldn't trust those solder connections....
Nov 13, 2011. 9:11 PMWesley666 says:
I would put my money on Fuse. The metal end caps look more like a fuse, as in Colorex's picture, you can see that fuse has metal caps on each end. As well, I have seen fuses that have a brown or white piece of paper material glued around them, as well as fuses that instead of being a hollow tube with a thin piece of metal are solid all the way through and are generally brown (Like the one pictured) or white on the outside. How close is it to where the power comes into the board? If there is a place for one of those adapters/wallwarts or an AC plug very near it, then it is probably a protection fuse.
Nov 14, 2011. 12:25 AMBurf says:
Its a ceramic fuse and it looks very like it is blown.
Nov 14, 2011. 4:54 AMjeff-o says:
Definitely a fuse. Hard to say what value it is, though. Do you have a multimeter to test it with?
Nov 13, 2011. 7:39 PMcolorex says:
Apparently a burnt fuse. That's exactly how they look in old computer PSU's. Of course they should be clear glass, but this one looks burnt.
Here's a pic of the fuse in an old desktop PSU:
I am not a technician, so don't trust me.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
