Is this a good pcb design practically speaking?
This is a design of a water level indicator based on a single NOT gate IC (HEF 4049).
UPDATE:
I redid the layout. Increased the trace width and attached the power to the IC.
Please tell me if this is ok?
Also please tell me is it must to have a power plane?
UPDATE:
1) i went back to original layout and beefed up the tracks
2) Made the IC pads bigger.
3) Was able to reconfigure the layout to connect power without jumpers (this took up most of the time).
4) Did as Verence suggested and put text on the copper layer. Version number, date and name.
5) And finally added the positive for the supply voltage.
UPDATE:
Moved track from pin 7 of IC away from pin 8.
Visit Our Store »
Go Pro Today »
- use wider tracks,
- connect Pin1 of the IC with Vcc
Some other things:
- a GND pin on J1 might be nice as you have to route the ground potential to your sensor part (maybe Vcc as well)
- add some text to the bottom copper layer (if you don't want to pay for a screen layer): project name, version, date, your name, copyright etc. Make sure the text is mirrored if it goes to any bottom layer.
- B1 is for the supply voltage, right? add some indicator for the polarity (and maybe voltage range) Or you might like to add a protective diode.
- add some holes for easy mounting of the pcb later
- are the resistors in the 0.1 inch grid?
I am going to etch at home using toner transfer so no paying for screen layer (whatever that is :-) ).
The polarity for the battery B1 is on the top silk.
The grid is 0.1 inch.
I'd would:
1) go back to your original, beef up the tracks (as you did)
2) You have loads of space around all your pins, make your pads bigger and oval on your IC. They're too skinny and will break when you drill or solder them.
3) Add the jumper that framistan suggests. The red and white wire he's drawn on his diagram that goes from pin one of the IC to the +v supply.
4) Do as Verence suggests and put text on the copper layer. Version number, date, name and a + for your positive supply connection!
I'm not familiar with diptrace but i'm sure it is able to check for errors, such as traces being to close and whatnot. Find that and run it cause it looks like the trace from D4 is too close to R11's lower contacts. You may have allot of traces that are too close together.
You may need to play around with the overall layout till you find one that is easier to rout all the traces with.
not be able to run that plus wire directly to the proper IC pin. this is because it
will cross over and connect to undesired terminals. You may have to go way
around the side of the board and then down to the IC plus pin. It appears you
need to connect plus and minus to a few things (the IC and the LED's. I have
used a paint program to roughly show the changes . The J1 and J2 are plain
wire jumpers you will have to add to the circuit board when you build it. It is preferable if your design can avoid using wire jumpers, but sometimes it
cannot be avoided on a single sided circuit board design.
