Is this capacitor bank enough for Railgun? Updated
I have connect the capacitors (5 of 150v 330uF and 1 from Fuji-film cracked camera which has already connected to the charge circuit board, so I don't know the detail) in parallel.
Is that enough for Railgun?
I have made rails with copper 5x15 cm.
I'm not sure that it will work.
Update....................................
Now I change them to be  5 of 350v 47uF and 1 from Fuji-film cracked camera which has already connected to the charge circuit board.
And increase the size of the rail to 10x2 or 3cm per one copper plate.
Is that enough? Or should I change something more?
Because I have seen somebody use only 3 of the camera flash capacitors and it works.
How do you know that it's ok or not? @3@
Thank you...
lemonie7 years ago
That's not a lot. 5x 3,300 would be more interesting.
L
seandogue7 years ago
Not for a rail gun, but for a gauss rifle yes. Rail guns and gauss rifles are different beasts.
The voltage is a bit low so don't expect to be the big new bully on the block.
Well yes and no. It will have enough power to fire a projectile but it will have to be small and you can't expect it to go very far ether. If you want a lot of power you should really go with something a lot bigger.
