Is this the right kind of Diode to protect a Servo with?
I would like to protect my Servos from accidentally reversing the voltage on them and frying them. The power source is 6v (4x AAA battery) and the Servos each draw a maximum of 6v, I am unsure about the amps due to a lack of datasheet, but have been told that they draw a maximum of around 1A per hour. I have 4x https://www.sparkfun.com/products/9347 and was planning to use https://www.sparkfun.com/products/10926 , one for each servo. Does this make sense/will work? Thanks in advance for your help.
iceng4 years ago
Almost any diode will do but for protection I would recommend
a GE glass bead diode because they can run red hot and not fail
on a accidental reverse hook-up and still recover.
You don't want to use a diode that fails, then burns open and
then the reversed power kills the servo.
So you want as a minimum a 6A diode that can handle a set of batteries
supplying lots of reverse current.
Looking at a Jameco servo that runs under < 500 ma ...
You could use a 1N4001 stronger 1A Diode and
also put a 1A fuse in series with the battery.
So if reversed the fuse blows protecting the diode and servo.
if it isn't a GE glass bead diode.
A
quatch4 years ago
for whoever wants to answer this, he is asking about a 1N5819 Shottky Diode, 1A 40V.
iceng quatch4 years ago
Thanks for the promo :)
quatch iceng4 years ago
Wish I could answer it for you. I know you are supposed to use a diode but I don't know about servos, or which kind diode to use.
