loading
I've made a hot wire foam cutter, but it is always burnig transformers. what should I do to avoid that?
can you give a schematic for your build? Are you running the wire straight off the transformer? What if any circuits do you have between the transformer and the wire that help limit the amount of current to the wire?
tgferreira184 (author)  mpilchfamily5 years ago
i follow this instructable:
https://www.instructables.com/id/How-to-make-a-simple-foam-cutter-from-scrap/
but I've used nichrome wire from a heater
Your problem is the wire your using. The wire draws way more current then what your transformers can support. Foll ow the intructable and use a guitar string.
how can I build it using nichrome wire?
lemonie5 years ago
I don't see any transistors in that Instructable.
L
You should design it with a view to how much power the wire will draw from the transformer.
That starts with knowing the resistance of your "hot wire".
Steve
