loading
Joe O---Easter Island Granite Resin Head Statue?
  • CAN I FILL WITH CONCRETE ?
  • Durable and realistic looking resin construction
  • Measures 27 in. H X 14 in. W 15 in. L
  • Realistic granite color
  • Features convenient fill-hole at the base to allow for sand filling, adding more stability This is a pretty good size statue, that's why I'm sending the measurements. How would you fill? Placing the head upside down, but the weight will increase as i fill. (dig a hole and place in side)? This will be heavy and hard to steal.
  • Need your recommendation.
  • Thank you,
    mikeasaurus2 months ago
    If your shape allows, it's best to cast with the shallowest dimension downward, thereby distributing the weight of the concrete. Alternatively, you can create a very robust frame for the casting, then make a mold to make the shape. Here's a link to a mold making class that could be helpful to use in conjunction with this class.
    jortizjrbsa (author)  mikeasaurus2 months ago
    Ill try placing face down at a 60 Degree tilt, then cut the back of the mold to make additional copy's.
    I just completed the concrete face lift on my other Easter Island head that is made from a plaster mold.
    It was pitted really bad. I filled the inside with plaster to save from breaking. The concrete is placed and it should be ready for the back side this weekend. When i complete that phase Ill paint it.
    Thank you for all the lessons and pictures for step by step proceedures.
