Joule thief 12VDC 3A?
Is it possible to build a joule thief to run a netbook? I mean feeding the circuit with a 9V radio battery and to have an output of 12VDC 3A.
rickharris5 years ago
Not surprisingly the answer is no - as below.
If your plan could work we could all be running our houses off a couple of 9 volt batteries.
No ! You're asking for WAAAAYY too much power.
+1
A joule thief is good for pulling 0.005 amps at 3-4 volts. It's the reason its called a joule thief. A joule is a remarkably small amount of energy :)
You can probably find a boost converter that will do the voltage conversion, but a 9v radio battery won't ...ever...output 36 watts.
+1 !
