3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Knexwise, do you prefer decent iron sights or a decent dot sight?
So which do you prefer...
which do you think would be more popular...
This should have really been a poll... but oh well.
I meant in terms of looks... because knex guns are so inacurate that it barely makes a difference...
Jan 30, 2011. 10:04 AMknexinventer says:
both
Jan 29, 2011. 8:24 AMCheezpaper says:
Well I like a mix of both. Instead of having the dot inside the scope, I like to have the dot in the front of the gun so it functions like iron sights but has the feel of a red dot.
Jun 25, 2010. 5:53 PMFred the Penguin says:
in knex terms they are basicly the same thing...
Jun 12, 2010. 3:04 PMTheChemiker says:
Who is Erikos Kostarikos? That is my own dot sight I came up with without seeing anything else.
Jun 13, 2010. 9:41 AMTheChemiker says:
A few months ago. If he made a dot sight before, I did not and still don't know about it.
Jun 20, 2010. 3:12 PMTheChemiker says:
I have no idea, I just know that I did not copy anyone.
May 22, 2010. 4:08 PM~KGB~ says:
dot sights feel more accurate!
Jun 13, 2010. 3:57 AM~KGB~ says:
y?
Jun 15, 2010. 2:30 PM~KGB~ says:
suppose...
Jun 8, 2010. 6:42 PMTheChemiker says:
They are way cooler!
Jun 13, 2010. 9:40 AMTheChemiker says:
People can have their opinions, but in the real world, you can aim faster, easier, and with more acurracy.
Jun 20, 2010. 3:11 PMTheChemiker says:
Since when does a dot sight cost $1,000? Iron sights have to be fitted right and adjusted well too, and dot sights work in all light conditions, and very well in the dark, and the battery lasts weeks, because they barely use any power. I have actually used a dot sight, it is on my rifle, and it cost about $50, and was much more accurate than the iron sights. Have you ever used a dot sight, or do you even know anything about this topic?
Jun 24, 2010. 3:08 PMTheChemiker says:
The US just doesn't use dot sights because they are spending too much money on M16s. The German army uses g36's which is a much better gun than the M16, and each one comes with a 3x scope and a dot sight built in, plus they are cheaper than the peice of trash M16. The US just doesn't want a german gun, they want to stick with American guns, even though they are worse. Even though most of that was pointless, the point is that dot sights are not that expensive, and are actually in use with other armies.
Aug 13, 2010. 8:13 PMKnex_Gun_Builder says:
ACOG, Aimpoint...
Aug 11, 2010. 2:26 PMKnex_Gun_Builder says:
M14 beats the g36's socks off.
Jul 8, 2010. 11:03 PMDrWeird117 says:
Actually, I heard from my brother that the SEALS are getting some UMPs. Of course...that was two years ago.
Jul 9, 2010. 9:30 AMTheChemiker says:
Woot! The US is actually getting a H&K gun! That is a massive improvement over the M16. Well, I guess some of the US forces are using MP5s, but they need more H&K and less Colt.
Jun 25, 2010. 11:57 AMTheChemiker says:
The g36 is actually cheaper and a much better and more reliable gun than the M16. The g36 kills the m16 in reliability, you can fire the g36 submerged if you wanted to, with just the barrel poking out. m16 is an over complicated peice of crap. The g36 is a simple, rugged and reliable weapon, with a higher rate of fire and accuracy. The m4 is basically a shorted m16, it has the same internals. A properly sighted dot sight is more accurate than iron sights. A scope on a siper sits high on the gun, and yet it is more accurate than iron sights, yes? Same with dot sights.
Jun 9, 2010. 3:42 AM~KGB~ says:
true, true
May 16, 2010. 10:25 AMsilentassasin21 says:
Well I prefer a good set of iron sights because there lower down on the weapon making them more accurate. But dot sights are cool looking they usually aren't accurate at all because there a inch taller then the iron sights.
May 20, 2010. 1:05 AMknexguy says:
That would make hardly any difference.  You're probably having parallax problems.
May 18, 2010. 9:34 PMTheChemiker says:
I like dot sights, I think they are more open and easier to aim with, just put the dot on the target, even though knex guns aren't super accurate.  =P
May 16, 2010. 7:57 AMTheDunkis says:
For functional reasons- Iron. They're just more open usually with less obscurity.
For aesthetic reasons- Dot. They do look better depending on how realistic you make them look. It's easy to mess up your aiming with these though as it's hard to level and center the sight on something.
But when in doubt, just make sure the gun has default iron sights with the ability for an optional dot sight attachment.
Does anyone else see the irony in having the dot sight on a shotbow?
May 18, 2010. 9:33 PMTheChemiker says:
Both of the oodammo stay in the circle formed by my dot sight during almost all of their flight, untill they hit the ground.
May 17, 2010. 10:58 AMTwistedParadox says:
No, what is this irony you speak of
May 17, 2010. 5:12 PMDJ Radio says:
More people use ironsights, but I think dot sights are easier to aim.  However, they do require a part which I don't have.
May 16, 2010. 2:24 PMRe-design says:
Dot sights for competition and open sights for combat.
May 16, 2010. 7:18 AMMr. Muggle says:
I like em both, technically they are actually the same with knex because there isn't a laser dot in knex guns
May 16, 2010. 5:42 AM182515 says:
I prefer Iron sights
May 16, 2010. 5:39 AMSeMi_AuToMaTic says:
It depends..... CQB or mid range?
Overall, probabbly the m4a1 iron sights rule.... as of knex, Your ACR sights. good job!
May 16, 2010. 5:36 AMTwistedParadox says:
I prefer the sights of iron (plastic really) cause I like it that way
May 16, 2010. 4:18 AMknexguy says:
I personally prefer iron sights generally, but it does depend on the situation.  However, I make all my weapons with flip down iron sights and a rail to install other sights etc.
May 16, 2010. 3:08 AMNachoMahma says:
.  This is an opinion question and much more appropriate in one of the fora.
.  I think knexpete did a good job of answering the question - it depends.
May 16, 2010. 4:16 AMRavingMadStudios says:
Mostly, it depends on whether the K'nexer is moving or stationary, and whether they're behind cover.
May 16, 2010. 2:39 AMknexpete says:
 well, it depends on the sights in question. I like any sight that is easy to use, accurate and not cluttered (i.e. both of the sights in the pictures) but in most cases, i prefer iron sights.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
