loading
LAWN MOWER ENGINE CONVERSION can a lawn mower engine be used to drive a hydaulic pump to operate a log splitter?
Phil B4 years ago
I just put together a log splitter for my son-in-law using various junk parts he gathered. He had acquired an Enerpac Hushh Pup electric pump powered by a 1 horsepower electric motor running on 120 volts. A hydraulic ram 2 inches in diameter and about 3 1/2 feet long came attached to the pump. It works quite well, although it is a little slow. My job was to attach the ram and the pump to the leftover portion of an old log splitter that is an "I"-beam with a slider to push the wood and a large knife to do the splitting. Another part of the job was to mount it on a set of wheels from the front end of an old riding lawnmower. All of this sounds rather simple, but there has been a lot of thinking, cutting, grinding, fitting, and welding to get all of the details as close to right as possible.
Burf7 years ago
Sure, the problem you will face is if the engine has a vertical drive shaft.  You're going to have to use a pump that can be driven by a vertical shaft or you will have to convert the vertical drive engine to a horizontal output in some manner.
NachoMahma Burf7 years ago
.  Many (most?) small hydraulic pumps will run in any position.
.  Shaft orientation should only be a problem with pumps larger than what is required to drive a DIY log splitter.
Prad (author)  NachoMahma7 years ago
would you happen to have a brand name or two that i can check out? thanks for your time and response.
NachoMahma Prad7 years ago
. <a href="http://www.northerntool.com/webapp/wcs/stores/servlet/product_6970_200321051_200321051">Pump One</a><br /> <br /> . <a href="http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=99742&xcamp=google&utm_source=googlebase&utm_medium=cpc&zmam=33951326&zmas=12&zmac=112&zmap=99742">Pump Two</a><br /> <br /> . *Not recommendations, just the first two pumps I found that _might_ work for your application.<br />
Prad (author)  Burf7 years ago
thanks for your response
Re-design7 years ago
Pick out you actuator and them see what the requirements are for power.<br /> <br /> <a href="http://weldingweb.com/showthread.php?t=23835">Here's a great link to a welding forum</a> and the post is talking about diy log splitter. The op wants to use electric but they digress into talking about gas powered. They figure 5 horse will make a good splitter.<br /> <br /> There's a link there for a good supply house for parts. You won't find what you need at the local hardware store but maybe the lawnmower and tractor shop is if it's a good one.<br /> <br /> Do plenty of planning before you spend a single dime on parts.<br /> <br /> Good luck and this sounds like a great instructable even if you only go to the planning stage.<br />
Prad (author)  Re-design7 years ago
thanks for your response, will definately research before spending that dime. The welding forum was a big help.
lemonie7 years ago
Probably. More details?
L
