loading
LED FADES OUT. WHY?
Hi ive attached a led to a couple of rechargeable batteries it begins with a bright light and starts fading and then reach a point where it doesn't fade out any more and stay like that for days. what shall i do to make the illumination of the led constant?
P.S. No capacitors were used
seandogue7 years ago
It starts with a bright light because the voltage on a freshly charged battery falls off very quickly in time to it's steady state value, so if using a simple resistive regulator (resistor in series with LED) the voltage across the diode junction is high, then drops to its steady state value, and a corresponding change in brightness is observed.
To make the brightness constant over the !life of the battery charge (until the voltage across the cell terminals is too low to be regulated), one would build a constant current regulator to drive the LED, rather than using a simple resistive regulator
Have you got a resistor with the LED ?
electrod (author)  steveastrouk7 years ago
no and if you could tell me whats the use of the resistiors in this case i would be grearfull.
Like Rory says, look at the link, BUT if you can find a figure called "Forward volts drop"  and "typical forward current" you can design the resistor by
Resistor = (Supply volts - forward volts)/ forward current.
Otherwise, for old fashioned little LEDs, recking Vf = 1.2 V and If= 20mA.
Steve
the led is not burned and if i turn the current down then start it again in around 15 m it goes bright again and start fading after a while again.
The resistor limits the current that can flow in the LED. You've been very lucky that the battery and your LED are pretty well matched, and the LED is still alive. It won't be though, unless you add the resistor.
Steve
Ok what you have burned out your LED, this is because the current passing though the led was too high. You need a resistor in series with the LED.
For more infomation on resistors and the current use please consult this page.
www.doctronics.co.uk/resistor.htm
Also the LED will not work again
Rory
