3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
LED circuit?
I recently purchased a few LEDs for a project, 2 blues and four reds. I need a way to power them all for months at a time. Would a nice soul be kind enough to draw up a schematic for me, considering I know NOTHING about this stuff? Here are the schematics, taken right off the back of the packets. 4 Red LEDs: Forward Current: 28mA max Forward Voltage 2.6 V max 2 Blue LEDs Forward (supply) Voltage: 3.7 typical, 4.5 Max Forward (supply) current: 20mA typical, 30mA max Any help?
Jun 25, 2009. 10:08 AMdeath defyer says:
there u go make sure the power supply is from a wall adapter of 12 volts or else a battery couldnt power it and if 100 ohm resistors dont work try 10k ohm
Jan 15, 2012. 1:13 AMBot1398 says:
Just rename it to .Sch
Jun 30, 2009. 2:02 PMdeath defyer says:
i am sorry i cant and its a .sch schematic
Sep 20, 2010. 9:40 AMkadris3 says:
red leds typically have 2.1 vdc at 20 ma. this is what you use if you want them to last. the screaming led specs you give a max(never exceed under any circumstances). they may last for a while using these figures. a 12vdc supply, that's exactly 12v will light 5 red led's in series with a 180 ohm resistor. if it is regulated 12v and never exceeds 12v then 100 ohms can be used.
for the white leds use 3.4 vdc and 20ma. 3 white leds in series with 180 ohms
works well. by the same token, a regulated supply can use 100 ohms for current limiting.
good luck with your project. unclecytheledguy.
Jun 26, 2009. 12:23 PMrickharris says:
http://led.linear1.org/category/led-basics/ will help you a lot have a look round the site and read up on LEDs
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
