3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
LED questions-- how many on a given battery and resistors with conductive thread?
How do you figure how many LEDs you can use with a given battery, . and why don't you need a resistor when weaving an LED into fabric.. or do you. Is there a diff between using conductive thread and wire in that regard....?
Feb 24, 2010. 6:39 AMsteveastrouk says:
What typical voltage and how many LEDs do you want to use ? On 5V a typical red LED needs aroun 150 Ohms of series resistance, that's 100" of your thread.
Altenatively, use ACTIVE control of the LEDs, by using a circuit like the one here. This automatically compensates for the wires for you.
Feb 19, 2010. 2:22 PMlemonie says:
This will give you answers:
led.linear1.org/1led.wiz
L
Feb 20, 2010. 10:39 AMsteveastrouk says:
Since the thread is a rather worse conductor than normal wire, its going to depend very much on the thread. I've seen some circuits where the thread itself can work as a resistor as you suggest, but I'm not sure its a good idea. the threads terminations, which are often wrapped around the edges of a circuit board, are susceptible to aging, and what was a pretty reasonable current limiting resistance when you made it, gets more resistive with time - so your LEDS get dimmer with time.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
