3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
LM386 amplifier overheating?
I built a simple LM386 based audio amplifier (schematic attached), but it appears to be over-amplifying, as it makes horrible squeaking noises and picks up a lot of interference. It also gets very hot in use, so I only switch it on for a few seconds at a time. I'm guessing this is because of the high amplification as I have a commercial amplifier that uses an LM386 and it does so without a heatsink, although unfortunately I can't reverse-engineer it and even if I did, my circuit would almost certainly have to be remade. I tried changing the potentiometer today from 1k to 10k and even 100k, but they didn't have much affect. What component(s) should I change to give ti less amplification, I only need about 2-6 times amplification, preferably adjustable but it doesn't matter too much.
Jul 12, 2011. 10:59 AMsteveastrouk says:
You have set the gain at 200 !!!
Remove the 1uF from 1 to 8
and add a 0.047uf in series with a 10 Ohm from 5 to ground, for stability.
The MINIMUM gain of a 386 is 20, so you have to do some attenuation on the input - mind you, you have a 40dB attenuation there right now. Ditch the 100K and put a 100K LOG pot on the input instead. See if that's where you need to be.
Steve
Jul 12, 2011. 11:16 AMsteveastrouk says:
No, its not that simple. You want POWER amplification, from a very tiny input power, to 1.5W, you may still find 20 is enough !
Steve
Jul 12, 2011. 1:02 PMsteveastrouk says:
No, a lack of stability is high frequency oscillation, which leads to catastrophic overheating.
Steve
Jul 12, 2011. 2:25 PMsteveastrouk says:
Could be damaged I suppose, check what current it draws with no input signal. It should be ~4mA
Steve
Jul 13, 2011. 3:47 AMsteveastrouk says:
Disconnect the speaker. Does it still get hot ?
Jul 13, 2011. 8:46 AMsteveastrouk says:
Sure your output capacitor's OK ?
Do you have an oscilloscope or access to one ?
Steve
Jul 13, 2011. 1:59 PMsteveastrouk says:
I suspect its oscillating somehow. Just try 100uF across the supply, and a 100nF in parallel with that.
Steve
Jul 13, 2011. 11:26 PMsteveastrouk says:
Not. 220uF 100uF in parallel with 100NANO farads (0.1uf) usually a ceramic cap !
Try another chip - I'd never buy off ebay for ICs there have been too many scams were the ICs are essentially scrap devices that failed testing in some way.
130 quid for a scope's a good deal.
Steve
Jul 13, 2011. 6:14 AMgmoon says:
If Steve's suggestions haven't worked, check the output coupling capacitor (C1).
Someone here had a similar problem because they omitted that cap (which blocks DC bias voltage from the speaker). Could be yours is damaged...
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
