Laptop LCD gone... no 2nd VGA port. How do I adapt/convert old LCD cable to 15pin VGA ?
Used in our motorhome while travelling. Had a little accident and the top lid was torn off, but it still works ! Would like to adapt it to use standard vga monitor.
New cell contract w/card co$t more than new laptop !
( FYI: USB convertors are avail, but cannot use the USB 1.1 port)
( eBay found an old 'base station' which has a VGA port, but,,, its 110vac only.)
Any thoughts ?
5
answers
Answer it!
But if the base station has the VGA connector, the circuitry probably is there; the hard part would be connecting to it.
Were I you, I'd investigate that docking station more closely. Often (a) the "110VAC" is actually just a matter of plugging the laptop's normal charger into the docking station, and (b) much/most of the docking station will work when operated off the laptop's battery. The latter would solve your problem; the former requires that you have a car adapter for the laptop, which I suspect you have already invested in.
If it really does need 110VAC, there's the option of getting a decent inverter -- sine or modified-sine -- and running 12V into that to get the 110VAC needed to power the docking station. Less efficient, but it would do the job, and since it doesn't have to be a _large_ inverter (I'd expect 100W to be plenty) it should be fairly affordable. And it would give you the option of running other house-current devices if you ever need to. Were I setting up a camper, an inverter would certainly be on my equipment list...
Good luck on your "adaptation".
Qa
Which one is it?
http://pc-dl.panasonic.co.jp/cgi-bin/itn/toughbook/dl01.cgi
(specifically)
What's this "base station"?
L
