Look.?
I’ve done 10 inches so far following the English method, If I now switch to trying the Continental method will the knit look different. Thanks
bekathwia1 month ago
Most likely yes, because your tension is bound to be different between the two methods if you're not equally adept at both. Perhaps try a swatch in continental until you feel like you have good tension control, then you should be able to match what you've already done in English. Good luck! Continental is a lot faster. =D
