loading
Looking for specific tubing fittings/fasteners. Do they exist and where can I find them?
 Hey guys,
I'm looking to design a project using Nylon Flex Tubing (www.smallparts.com/Nylon-Flexible-Tubing-Wall-Color/dp/B00193UJ7Q).
The project design, as I have it in my head, calls for two fittings/fasteners that I can't seem to locate. The first is a fitting that will allow two pieces of tubing to cross over each other at a 90º angle. (First Image).
The other is a simple series of fasteners that run parallel to each other to hold multiple pieces in place. Ideally, I need 6 channels. (Example, Image 2).
Please let me know if you have specific links to or names for these types of fasteners. If you find the fasteners will not work with the type of tubing I've selected, please note that. I need tubing which is white translucent and quite flexible. Thanks, guys!
Picture of Looking for specific tubing fittings/fasteners. Do they exist and where can I find them?
kelseymh7 years ago
McMaster-Carr catalog pages 1496-1499.  Or, in the search box type "tubing clips" and go from there.
BretMattingly (author)  kelseymh7 years ago
 Pretty much exactly what I was looking for (at least the parallel pieces), but I think I've decided on having custom fittings RepRapped.
BretMattingly (author) 7 years ago
 I'd rather have the tubing run through the 'fasteners' rather than connect to, if that's possible.
Short lengths of PVC glued together?
You can make these for yourself using straight barb connectors and plastic cement. For the parallel one, you might add a plastic strip with three holes to space the barbs out enough to leave clearance for your tubing.
I agree. That's what I was going to say.
