3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Looking to brainstorm about a Jacob's Ladder-style prop weapon - Grendel's Fork
I have a friend who is a big fan of Matt Wagner's Grendel comics, and I thought it would be fun to make him a prop version of Grendel's signature "fork" weapon. I can handle the construction of the staff and the blades, but I'd like to get some thoughts about the special effect - a Jacob's Ladder-style electrical arc between the blades. Obviously, I'll need to modify the pictured design a bit so that the blades are electrically isolated from each other - no "tuning fork" configuration.
My first thought was to just get a commercial "stun gun" and attach one contact to each blade, but I'm hoping the 'ibles community can help me come up with a better idea.
Desired Specs:
Hollow, black anodized metal staff. 6' length, 7/8" ID. Separates in the middle via a screw-threaded coupler. Has a threaded socket in one end and a black plastic plug in the other end. (It's an extra upright from a utility shelf unit)
Blades - not purchased yet, most likely 440 stainless tanto blades (dulled)  7" to 10" plus a 3" - 4" tang.
Unit must be self-contained - no power cord visible i.e. to an external battery pack or wall wart. A removable recharging cable would be OK.
Arcing must be triggerable via a switch on the staff.
I don't need to actually shock anyone, I just want a flashy visual effect. Simulated arcing would be perfectly fine as long as it looks good.
Needs to be sturdy and fairly impact-resistant. It won't really be used as a weapon, but it will undoubtedly get played with a lot.
Anybody have any suggestions?
Feb 23, 2010. 4:12 PMRe-design says:
Making it self-contained is gonna be tough.  For a spark of about 1" you need about 10 K volts.  You can get that with a flyback transformer from a color tv but hiding it in the handle is going to be the challenge.  You might modify it some with a bulge of some sort at the opposite end to hold the batteries, driver circuit and the transformer.
Feb 24, 2010. 4:43 AMRe-design says:
You know, I'd forgotten that a stun gun will make a continuous spark.  That might work.
Feb 24, 2010. 2:14 AMframistan says:
I believe building an ACTUAL high voltage device would not LOOK impressive... nor would it SOUND impressive.  I think you should look into building an LED circuit that would flash led's sequentially or back and forth.  Then a speaker could be added to play the sound effect you want.  Or if you are working with cameras, then the effect could be added in post production using editing effects.  The circuit to build is called a RING COUNTER.    The circuit often uses an IC called a 74154 (four to sixteen line decoder) and also uses a 74193 (four bit up-down counter).  I have schematic if you cant find it on google email me if you want it.  The LED's would be much brighter and colorfull and safer than actual voltagesparks.
Mar 24, 2011. 9:15 AMredcode10475 says:
I've been looking to do this same project for a long, long time. I'm the same age as your friend (45) and a Grendel/Matt Wagner fanatic. The way I figured to do it was use a faux tuning for configuration with a separator of either silver painted wood or metal separated by rubber dividers.
Because of the small, compact shapes of many stun guns, you could easily fit the components length-wise into a hollow metal shaft.
Feb 23, 2010. 11:58 AMKiteman says:
(Wouldn't this make a better forum topic?)
A FunFlyStick has a small VdG generator in the handle.  Would something like that, with each end connected to a tine of the fork, produce enough of a spark?
Or maybe a beefed-up camera tazer?
May 18, 2010. 6:04 PMScubabubba says:
2 years ago, I'd have said "come get the big box of used disposable cameras and LET'S FIND OUT! YEAH!"
But I made the mistake of storing them inside and the wife found them.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
