Hi! I would like to make, buy, or find, a low voltage high amperage transformer to power an electrolosis cell. I like playing with the hydrogen-oxygen gas produced. From what I have read, I only need about 1.8 volts for electrolosis, so I'd like a circuit or transformer that could take the power from preferable a 9 volt battery and convert it to 1.8v at as high an amperage as I can get. Thanks : )
Don't use batteries it will suck them dry very quickly. And besides transformers only function with AC power, which you would need an inverter to run from a battery. If you had to use a battery you would want a car battery, you could probably find one easily, and they can put out HIGH amperages for short periods of time. If the 12V is just overkill you can spread it out over several cells like Christmas lights.
just the other day, i rewound a Microwave transformer. its not very hard to do, and it does product the desired current and voltage. UNFORTUNATELY AC current does not split the H2 and the O2. DC is required.
You need a bridge rectifier to convert the AC voltage to DC Voltage . on the secondary windings of the transformer in order to produce the DC required for electrolysis. A bridge rectifier is simply a set of 4 diode connected in a square with the poles facing "+" to "+" on one side and "-" to "-" on the other then joined together on the other ends. Like so: T1 ++ / \ - - L1 ____ + +____L2 \ / - - T2
L1 and L2 are the line voltage AC coming in T1 and T2 are the DC output.
That sounds great! How would a go about rewinding one, after I find it?? What gauge wire would I have to use?? Would I be able to get that much from a 9v? Would the battery die almost instantly?? Sorry about all the questions, thanks a lot! : )
You can get the transformer from a dead microwave (you should be able to get one from craigslist for free) the higher wattage the microwave is the more power you will get out of the transformer.
Microwave ovens have a large capacitor you have to discharge before touching any of the wiring; you don’t want to get zapped by it.
Once you get the transformer out you will want to cut off the secondary winding (the large coil of thin wire) but don’t damage the primary winding (the coil of heavy wire) you will wind some heavy wire where the secondary was. The voltage is typically .8 to 1.2 volts per turn on the secondary (depending on the transformer) you will want 3 to 6 volts for your hydrogen generator.
8 or 10 gauge wire should be heavy enough for what you need. That should give you 30 to 50 amps (more than enough for a large hydrogen generator) but heavier wire could be used for more current. The output will be ac which will be fine unless you want to collect the hydrogen and oxygen separately.
Be sure to put a fuse on the primary and secondary of the transformer. The transformer should be placed in an enclosure to prevent anyone from coming into contact with the dangerous voltage on the primary.
Google "how to rewind a microwave transformer" and you will find a lot of info.
This instructable gives some onfo on rewinding a microwave transformer.
sorry to add up the comment in btwn but i have a question ... what if i wanted to have a same voltage like around 3 to 10 volt but way more higher current .. like around 20,000 to 40,000 amps ... is it possible to get something like this from microwave transformer ?? or can i just add few more transformers in series and obtain more current? plz let me know as i m working in a project that requires amps in k .. so any thing starts with 20k amps works ... thank you and i m in time line to finish this project up .. so help me out over here and i'll really appreciate it ;) thanks
Thanks! : ) There's a lot of helpful stuff there.. So, what I'm thinking, is that I'm going to take a 9v battery, through a 555 timer for oscillation, and put it through this modified MOT and that will give me the power I'm looking for?? Or you're thinking I'm running the transformer from 120v AC and I have it all wrong?? : ) Thanks, this is a lot of help. Sorry about all the questions..
The mot runs off of 120v ac (or 220 depending on where you are). A 9v battery won't provide more than a few watts of power. If you needed the hydrogen generator to run off of a battery and produce a usable amount of gas you would need a car battery.
batteries? *pfftt... Try re-winding a MOT (microwave oven transformer) with about 3-4 turns or REALLY thick wire, I've seen people get Hundreds of amps out of it see http://www.instructables.com/id/Homemade-Spot-Welder/?ALLSTEPSJust look at the transformer.
9v batteries are piss poor for high current applications, you would be better off with 2xNiMH "D" cells or a small Ld-Acid battery, You can buy singly cell Ld acids that put out 2v with whatever A/h your prepared to pay for. As for using a transformer with a battery it's more trouble than it's worth, you would basically be building a small inverter, you can get single chip voltage regulators if you want to control the voltage but they arn't much good for high current applications.
Ok...where can I find the MiMH batteries, or the Ld ones?? I realize I'd be building a small inverter, which I think would be fun if I got it right. A voltage regulator wouldn't increase my amperage would it?? I have never used or seen one, so I don't know.. Thanks a lot : )
rechargeable AA batteries are nimh car battery is ld. there are smaller lds (sealed lead acid battery) you understand the inverter and volt reg part correctly
Thanks again : ) Where would I be able to find a smaller ld battery, like you suggest?? I'm assuming it's going to be rather expensive, heavy, and can't be salvaged from anything I could find easily?? Thanks!
they are used mostly in computer UPS / some emergency lighting fixtures / other emergency related stuff they can give about 10 - 40 A (depends on exact battery) without damage (they can much more but will have short life) they dont have very much life in them especially if you discharge them a lot. (most are designed to wait all their life to emergency that never happens). and you need to bother about charging etc its better to use line powered power supply like the microwave transformer or computer power supply
Bio:Hey everyone. I graduated from high school in spring of 2012, and will be a Chemical Engineering student at the University of Toledo in the fall of 2012. I have a wide variety of interests and skills...read more »
PDF Downloads As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
T1
L1 ____ + +____L2
T2
BTW high amps can kill you.
if thats too much of a hassle you can use a PC (AXT) PSU like http://www.instructables.com/id/Computer-Power-Supply-to-Bench-Power-Supply/ And make it http://www.instructables.com/id/Convert-an-ATX-Power-Supply-Into-a-Regular-DC-Powe/?ALLSTEPS
hope i helped
