MIDI Drum set using keyboard?
Im wondering if I could make some piezo drum triggers, run them through and Arduino or other device, and then send MIDI signals from the Arduino to a Casio keyboard I have.  The keyboard would play the drum sounds.  So basically the triggers send a signal to the arduino and the arduino sends a signal to the keyboard.  Is this possible?
orksecurity6 years ago
Assuming the Casio accepts MIDI commands in, sure.
view my instructable:-
https://www.instructables.com/id/WORLDS-CHEAPEST-VIRTUAL-DRUM-at-10-Rs500-us/meta-stats
Seconded. You need to do a little filtering and amplifying to make the piezo work -- if I remember the circuit, a piezo puts out millivolts on striking, so you just need to amplify it with a transistor or two. An RC filter can be included to debounce the circuit (since many 'hits' are vibrations, you may get many hits unintentionally. It took me a long time to find the circuit diagram for piezo to TTL signal. This amplification may or may not remove the velocity (amplitude) aspect of the output.
siddiq43215 years ago
siddiq43216 years ago
this siddiq , India,
i have a very cheaper and working method :
1)use the software flexi music orchestra - a very user friendly software to play wav. files etc. on the keyboard
2)download yamaha / ronald / alesis drum samples over the net or from torrents ...they are very quality one and ull have no complaint
3)load all these sample to the key u want for EACH drum/cymbal ...which is pretty lengthy and save it ..
4)then comes the hardware ...use and old PC keyboard -ic ...or if u get confused with the ic pins j...just keep it attached to the plastic sheets which are below the keys ...and the pass out a pin ter . rhe conductor holes ..which is again a time taking job ..but cheap and working
5)now on other ends of the wire ..anttach a piezo...which is the cheapest drum trigger ..of if u r keyboard does not get enouhgh gain on tapping ...the attach 2 /3 in series and keep one above another ,,....and place it beneath the mouse pad (to experiment ) ..the strike u r mouse pad to play ....
was it helpfull ?????/////////////////////////
don't forget to tell me how was it .....
Replyflag[delete]
