Making a soundcard - Can I have two separate inputs, using a single PCM2900 chip?
Which pins are inputs?
Can I add another input or two using the same chip? or do I need another?
I am following this example... http://www.netams.com/~anton/usb-adc/index.html
Visit Our Store »
Go Pro Today »
"After a careful research, a Texas Instruments PCM2900 chip [1] was chosen as a proper converter (fig.1). It has a stereo I/O (only input is used in this project), USB interface and MS Windows drivers already shipped with an OS."
The larger "Reference board circuit diagram" is easier to read. The inputs are VinL and VinR (Voltage input Left, Voltage input Right).
So yes, it has two inputs.
You COULD add a multiplexer, but you'd have to switch that with something you can drive via USB, the chip has digital input pins, but not outputs you could've used to operate the MUX
I do not know the chip, but if takes analog, then could a simple op-amp mixer
allow for multiple inputs ? . . . . . A
