Making printed circuit boards without laser printer?
I am into electronics, but have had to use pre made PC boards. there is nothing wrong with this, but it can sometimes be inconvenient, and more difficult when the time comes to put the circuit board together. I have seen instructables on how to make custom printed circuit boards, but they all used laser printers. I do not own a laser printer, and cannot really afford to buy one. Is there a way to etch boards without a laser printer, and if so how?
It depends on what sort of PCB you need - You can buy resist pens and draw the circuit.
You can get a photo copy of the circuit and use that as per laser printer print transfer
You can/could buy PCB transfers that allow you to build up circuits.
You can use practically anything that will resist the echant and scratch in your outline.
You can use strip board as another way - This works for fairly complex dense circuits.
You can use perforated board and join components with wire. http://www.rapidonline.com/Tools-Equipment/Stripboard-29453/?sid=07bcda88-608d-45c8-a91d-aaa41afb3446
Oh and you can go the old way and print your design onto acetate sheet with an ink jet and then use a light box (or sun light) to transfer to sensitive PCB material.
I was wondering, does the time between printing/photocopying and ironing to PCB play a role? If one can get a photocopy somewhere far from home, is the toner still able to stick to PCB after hours (or days)?
so for the resist pens you would basically just draw the circuit onto the pcb and then place the board in ferric chloride, for a period of time, drill the holes and it should work?
PDF Downloads As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
Develop and etch.
http://www.solarbotics.net/library/techniques/buildpcb.html
Best of luck!
