loading
Motion activated music playback
I am trying to make a motion activated music playback device for a charity Christmas tree. Playing back an mp3 would be ideal. Playing back a recorded file like an answering machine would work as well. I'm looking to do it relatively cheap if I can.
Thanks!
S1L3N7 SWAT7 years ago
You could probably use this with the IR sensor in conjunction with an Arduino or similar:
http://www.sparkfun.com/commerce/product_info.php?products_id=9356
Very nice to make a playback device for a charity Christmas tree.
I don't know how to trigger mp3.  Hopefully someone here can help with that.  As for playback modules, they are generally triggered by having their playback switch momentarily grounded.
One approach is to have a device triggered when a light beam is broken.  There might be an Instructable on that, or info on the Internet.
I have experience with  the Sharp IR proximity detector (up to 1.5m)  http://www.trossenrobotics.com/sharp-ir-distance-sensor-gp2y0a02yk.aspx,
$UDS 15 and the Radio Shack PIR sensor (detects up to 5 m)  $US10
http://www.radioshack.com/product/index.jsp?productId=2906724&tab=summary
Both of them put out a positive voltage when they "see" something.  This could be used to control a relay or transistor to turn on your device.  Unfortunately, they are not cheap.
An alternative is to obtain a toy that senses persons at a distance, tear it apart, and use it's circuit.  I Googled "proximity triggering toys" and found a couple of references for you.  There are probably more.
http://www.reuk.co.uk/PIR-Sensors.htm
 http://lowtech.propositions.org.uk/lowtech-sensors-and-actuators.pdf
As again when you have decided on a detector.
How much time were you thinking of storing ?
Steve
