Moulding plastic - for a knife handle or holster ???
Hi ... I would like to ask fro help to find the proper ENGLISH word/name for what I'm looking for.
I would like to make a plastic handle (for a knife) and a holster. My grandpa had a stuff for this, where he moulded it, put the metal part of the knife handle inside and left it to become hard.
I have found something like the POLYMORPH but I'm just a little bit concern - wouldn't it be to soft ??? Or the low melting point ???
The stuff that my grandpa used became hard as a rock. And when you wanted to remove it, you had to break it ... and it breaks exactly like rock, glass (it wasn't soft).
Thank you in advance for any suggestions.
Nov 13, 2010. 12:51 PMsteveastrouk says:
Epoxy resins, or polyurethane resins are the things to use.
Steve
Nov 13, 2010. 8:16 PMaeray says:
I believe you are looking for Kydex, like this: http://www.instructables.com/id/Fun-With-KYDEX/
Nov 14, 2010. 8:48 PMaeray says:
Kydex is mostly PVC and CPVC, materials most easily found in plumbing piping. Instructables member Thinkenstein is the undisputed master of PVC here, so I'd suggest checking out some of his stuff.
Nov 13, 2010. 1:51 PMkelseymh says:
There are three brand names that I know about, Polymorph, Shapelock, and Friendly Plastics. They are low temperature (about 55-60 C) softening, which you prepare by simmering in water, and they harden quite rigid at room temperature. They're reusable, so if you just reheat it, you can remove it or reshape it as needed.
A recently featured Instructable uses Shapelock; you can find comments and sources there.
Nov 13, 2010. 12:52 PMrickharris says:
polymorph sets hard - you can drill it etc after it has set.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
