Multi use welder ?
Hi I'm looking at this welder http://www.everlastgenerators.com/product/multi-pr... for rebuilding a classic truck. Mostly sheet metal repair and some frame welding.
Thanks in advance.
Perri
audreyobscura7 months ago
That looks like a cool machine! Never seen anything like it.
Using a stick welder for thin sheet material can be tricky. How deep of a weld will you need to get for your framing?
I like using an TIG torch for sheet welding because it's quiet and clean. (My favorite kind of work in the shop :P)
Have you used a TIG welder before? It takes a little practice to get your wire feed right so be sure you have lots of scrap material around.
Ahptwa96 (author)  audreyobscura7 months ago
Most of the frame is 1/4" , I've done very limited welding. The benefit of this welder would be cutting, MIG , TIG and Stick all in one. Thanks for your help.
PaulC46 Ahptwa964 months ago
The Everlast machine you referenced does not have mig capabilities. There are several Everlast machines that do have Mig/Stick/Tig (lift tig) capabilities. Hope this helps.
