My computer keeps making annoying beepy noises.
And has been doing so for the past 6 months. I have been able to deal with it for this long, but it has finally gotten to me.
The computer is a HP Pavilion dv7 running Windows 7 Home Premium. It is not coming from the speakers, I think it is coming from the circuit board. I am sure it isn't coming from the speakers because 1) When the headphones are plugged in, the sound still comes, but not from the headphones (all sound reroutes to the headphones when they are plugged in) and 2) The sound still comes when the volume is turned all the way down.
Please help, it is SO annoying.
Thanks!
Jun 11, 2012. 11:14 PMjanderek says:
Its seems that your RAM or memory is not properly inserted.
Mostly beeping error is from memory. try removing your RAM then clean the lower part with an eraser.. Then try inserting your RAM again..
To read more about this try looking here : http://www.techyv.com/questions/how-do-i-interpret-computer-beep-codes
Aug 7, 2010. 9:48 AMBurf says:
Those beeps are there for a reason, your computer is audibly advising you of your computer's start-up condition. The beeps aren't random, they are in an easily decipherable code that can help avoid system problems and crashes.
The codes vary depending upon the BIOS that your mobo uses. The codes to most of them can be found here:
www.computerhope.com/beep.htm
If you are determined to disable them, there are two ways, one is to open the CMOS and disable them there. You'll have to check with your manufacturer's site or your instruction manual for the specific procedure.  Some Mobos use a wired connection to a small speaker and you can just unplug it. And as before, you'll need to check the manual or the manufacturer's site for the specific connection.
Aug 7, 2010. 10:39 AMBurf says:
Okay, it has to be a hardware issue of some kind.
The first thing I would check is for overheating, make sure the laptop is well ventilated and the vents are not clogged or blocked. If you know how to open the case, I'd do that and give it a thorough cleaning internally. If that doesn't do it, your options are to try and trouble shoot the system and see if you can determine what is causing the problem.
If you have a good HDD you can swap with the one you now have, you can try that as a test. Same goes for RAM.
Beyond that check the manufacturer's site and see what you can find there.
Aug 7, 2010. 11:12 AMBurf says:
Try elevating it a little so air can circulate underneath and maybe even direct a small desk fan so that it blows air under and around it. See if that helps.
Jul 12, 2011. 7:58 AMdidgitalpunk says:
true it might help and if it solves the problem, i suggest you buy fans that clip on your laptop. i know cooler master does them.
Aug 8, 2010. 2:29 AMlemonie says:
Jul 12, 2011. 7:37 AMdidgitalpunk says:
what is yourmotherboard number and is it an intel motherboard?
Jul 12, 2011. 6:52 AMdidgitalpunk says:
i found this site while searching for bios beep codes http://www.bioscentral.com/beepcodes/mylexbeep.htm
maybe it can help
Dec 30, 2010. 7:18 PMawesomeman2468 says:
it could be a number of things i know when my computer wiggles its cable out of the wall it makes a beeping noise
and or it could be a waring signal
Nov 14, 2010. 4:52 AMnebih says:
have you checked your circuit board yet for any bulging capisitors?
Aug 7, 2010. 11:15 AMRe-design says:
Go to HP.com and download the latest drivers.
The kid that works for my has an HP laptop that was over heating like yours and it had other problems like slow startup, running slow.  But I don't  think he was having the beeping problem.
Anyway he downloaded new drivers for it and most of his problems went away.  Seems there was a period of time where most of the HP computers had an overheating problem that was curable by updating drivers.
Might just work.
Aug 7, 2010. 4:35 PMRe-design says:
Motherboard specific drivers.
Aug 7, 2010. 4:37 PMRe-design says:
Google Hp overheating and go thru the list. Is it you laptop that's getting hot or the battery. There are issues with both.
Aug 7, 2010. 11:55 AMAnthrogeek says:
I had the same issue with my HP pavilion DV6. I went to power options and changed the power plan to a lower setting. The beeping stopped. Haven't had any more issues with it. There is a setting in Win 7 where you can turn down your processor so it won't get so hot. If it doesn't work then you should think about sending it in for repair, if you are under warranty.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
