loading
NDS-Lite shuts off randomly, sometimes 2 minutes working fine and sometimes 10 minutes then shuts off.
My NDS Lite shuts itself off at random intervals, it can run for 5 minutes very well then it shuts off, other times 1 minute before shut down, it does this randomly, can anyone suggest a solution?
KentaGrace7 years ago
First, need to ask, have you opened up this unit and taken a look inside?  This sounds similar to what happens if you have a loose connection to the flexible circuit cable that connects each of the screens to the main board.  This could be the issue, otherwise a common problem which may or may not cause your symptoms is that one or more fuses may be blown out in your DS.
