Need a 36 V schematic battery charger for a golf cart.
Is there an iintegrated circuit that you can tap in to a 120VAC  and convert to 36VDC @10-20 Amps without using a transformer> Have An Everest and Jennings 24 V @10 A model 11350 need output cable pin connections ? Bob
Picture of Need a 36 V schematic battery charger for a golf cart.
mrmerino4 years ago
Without a transformer, there really isn't a good way to do that.
rickharris4 years ago
It almost certainly has 3 x 12 volt SLA battery - connected in series. If you undo those connections you can charge 1 battery at a time with a 12 volt standard battery charger or indeed buy 3 battery chargers and charge all 3 at once -
Remember to undo the series connections first
...or float 'em......
iceng4 years ago
Listen to Steve
There are several but each will be using a transformer or inductor at
those specifications.
Ever consider charging the 12V batteries as three separate units at the
same time, avoids all sort of problems :-)
A
No, but you can buy chargers fairly easily.
