Need a Motor for ASTM testing: 1-5 RPM, ~150 lb in of torque. Any ideas?
I need a motor with low speed and high torque as described above. Thinking about using a 12V power supply but I'm flexible there. I've tried gear motors but I can't find any with the characteristics I need.
The application: motor needs to turn a screw that is fixed until the screw fails. After I have the motor I need I'm gonna have to find some way to graph the torque vs. speed curve.
Can't spend a fortune but willing to spend up to $100 because it's time critical.
Summary:
Needed
RPM: 1-5 RPM
Torque: 150 lb in
Cost <=$100
Thank you so much for any suggestions!
What's that in SI units ? Around 17Nm, quite a lot of torque. Look for a worm based motor- gear box. You should be able to pick something on ebay
Steve
nkay3 (author)  steveastrouk5 years ago
thank you Steve, I will look into that
