Need expert engineering help to build a foot-bridge!?
I want to build a foot bridge across a creek! The width of the creek is 16', but I'm going 24' long to support the footers. The bridge itself will be 4' wide. I was thinking of using "C" channel iron welded onto I-beams to hold the treated 2x6's in place. I need info on what type and size of beams, etc. If it's not too obvious I'm a complete engineering noob, but this is the kind of project that makes country living worthwhile.
Thanks in advance for your kind help!
Slim495 years ago
For Nice robust design,
wanted to share a roof truss building trick form the wilds of W.Va.
to make your own laminated/glued 2"x12" boards.
just
add a layer of Aluminum flashing glued in between the boards.
due to the Shear strength of the metal it becomes very rigid.
Mr Steve
Burf6 years ago
Unless you are planning on using the foot bridge to ride horses, large livestock or a Harley Fat Boy across, I would recommend using a couple of treated glu-lam wood beams for the base beams. Two 4" x 8" glu-lams spanning 24' can easily support 1200 to 1500 pounds live load.
Your savings in both money and labor will be substantially reduced and with using treated lumber, galvanized bolts and lags and periodic maintenance, it will last long enough so that a need to replace it will only become an issue for your grandchildren.
I didn't know manufactured/laminated lumber was available in PT. Good to know!
Ah, sorry, I didn't mean to imply there are pressure treated glu-lams, I was referring to something like this:
http://www.bluwood.com/product.php
To the best of my current knowledge, GL will void their warranty it their product is pressure treated. I should have been clearer in my statement.
Thanks. I should have said "outdoor-suitable laminated beams". I'd only seen them used within structures.
Yeah, sometimes it can be tricky using generic terms to define specific products. There is a tendency for brand names to become generic for all similar products.
I have used Bluwood in the past and found it to be excellent. I know there are other brands and processes but I have never used them.
Like most other treated lumber, dust masks and filters are imperative when cutting or sanding.
rickharris6 years ago
What kind of load is required
What budget do you have
What skills can you employ - Wood work - Metal work - welding etc.
How critical is this bridge i.e. how many people may die or be injured if it fails?
For my part for pedestrian traffic I would take a clue from house building. Use bricks to build 2 firm well established piers at each side of the span.
Put across that span 2 or 3 wooden beams such as you may see spanning that sort of gap in a house. say 8 x 6 inches. made from good solid knot free wood.
These sizes depend much on the distance spanned and the weight it has to carry.
Bridge these with planks to make a floor and the fit a side rail
Here is a link to a site with information on constructing basic bridge trusses:
http://mysite.du.edu/~jcalvert/tech/machines/bridges.htm
Great link. Civil Eng 101
Cool link !
iceng6 years ago
Hard to find a welded footbridge.   A
That was sorta my own reaction -- how many cars is this intended to carry per day? It sounds like you're seriously overengineering... and in a race between metal rusting and wood rotting I'm not sure the metal wins.
Websearching for "foot bridge plans" finds both free and for-pay resources. Your proposed length is larger than most of the free plans, but it looks like some of the examples at http://www.woodworkersworkshop.com/resources/index.php?cat=420 get that large and larger. (Design drawings for a 1920's 60' covered bridge from the New Brunswick Department of Transportation?)
