Need help making Sata Power to USB - 5V.?
So basically I have a 2.5" Sata drive that I want to use with my W500.
The drive itself runs at 5v 700mA and I know that USB's support 5v - what im looking to make is something similar to:
http://www.ebay.co.uk/itm/USB-2-0-SATA-7-15-Pin-22Pin-Adapter-Cable-2-5-HDD-Hard-Disk-Drive-/170883882967?_trksid=p4340.m1374&_trkparms=algo%3DPI.WATCH%26its%3DC%252BS%26itu%3DUCC%26otn%3D15%26ps%3D63%26clkid%3D2166192030703395264
or better still this:
http://www.ebay.co.uk/itm/USB-TO-SATA-converter-cable-/300775404093?pt=UK_Computing_Drive_Cables_Adapters&hash=item46079c723d
Any help would be great.
frollard4 years ago
There is no direct pin conversion between usb and SATA. They are different protocols.
You need a proper usb>>sata conversion cable if you wish to plug in a sata drive to a usb port.
To add to that... Even if you get the right cable and get the right translation between protocols to happen you will have a problem powering the drive. The USB spec calls for USB ports to offer a max of 500mA. So the power from the USB port will not be enough to handle the drive.
often, usb>>sata cables will have a double usb plug, one for data+power, the 2nd (often red) is just for power from a 2nd usb port. Laptop drives can often run on a single usb port if they use a soft-start motor, but a full size desktop drive really wants a full power supply.
lshoesmith (author)  frollard4 years ago
I actually should have put that in... I have a Sata to USB converter -but it is simply the communication device and provides no power.
It is the power that I am struggling with.... I thought that a dual USB setup might solve the problem but didnt want to do anything before confirmation.
Like I say the drive is a 2.5" Sata - it came from an old Macbook pro - so Im not sure if it has a soft start motor or not - but I am definitely not looking to power a 3.5" drive.
I've never seen a usb>sata that didn't have either a power input or was self contained and just 'worked' with enough input.
This is what I have:
http://www.ebay.co.uk/itm/USB-2-0-to-IDE-SATA-2-5-3-5-Hard-Drive-Converter-Cable-/300689677534?pt=UK_Computing_Drive_Cables_Adapters&hash=item4602805cde
With a separate power connector - e.i power brick converter with LP4 connector with LP4 to Sata converter.
http://www.ebay.co.uk/sch/i.html?_nkw=sata+power+adapter&_sacat=0&_odkw=sata+power+supply&_osacat=0&_from=R40
Virtually any 5v adapter should work with a molex>>sata power adapter (most drives come with one).
Yeah that is how I have been using this adapter thus far.
However I know have a W500 (Windows 8 tablet) and wish to take the 2.5 drive with me as I move from place to place, not having to 'plug in'. Hence the issue.
Again my fault for not specifying.
tablet computers are notoriously bad for not putting out much power on the usb port, you're probably stuck with the plug in, or getting a lower power drive
