Need help with a circuit.
I want to make a circuit that lights up 14 LEDs in parallel. The LEDs require 3.2 volts and 20mA each. If I use a wall wart that supplies 9v dc and 350mA, What resistors will I need and how should I connect them? Also can the current blow my circuit?
Re-design7 years ago
Try this led calculator.
sweet! Now is it possible to have too high of a current? and can it "blow" the circuit?
An led is essentially a short circuit. If you put .001 volts over the voltage drop of the led, it will spike the current far above what the led can tolerate, it will overheat and quickly die. Enter the resistor. It converts the series circuit from a short circuit to a 'fixed resistance' circuit which will tolerate the extra voltage without destroying the leds.
You can just put series' of three in parallel. That way you would be dropping 3V across each one without needing a resistor. Not to mention the open circuit voltage on wall adapters is a good bit above what is stated on the supply.
lemonie7 years ago
OK straightforward. Re-' says that at 9V you'd need 7 pairs, because 3x is over 9V. Can you get a higher-V supply?
L
