Need tips on starting Lantana from seed?
I have tried starting seeds in paper towels dampened and directly in potting soil inside the house and no luck starting them. Any ideas would be greatly appreciated. Thanks
Apr 2, 2012. 11:44 AMcanucksgirl says:
The Lantana seedpod is actually a berry, or a cluster of seeds that are very woody. In order to germinate the seeds you need to "nick" the outer shell in a process called "scarification" before soaking in water for 24 hours. After that, remove the seeds and lightly cover with soil, and ensure it is watered well for the duration. The Lantana is a winter propagator, and usually needs 180 days. (60-90 or more days just to germinate, and then another 90 to be large enough to plant). Due to the long cycle, most gardeners will start seeds in the Fall, so the process ends in the Spring, but you may still have luck if you keep them indoors (with a grow light) until they can be planted outside (based on your zone and climate).
(To "nick" the seed, you can use fine sandpaper to remove just the outer shell of the seed on one side).
Let me know if you need more help. ;)
Apr 5, 2012. 8:19 AMcanucksgirl says:
You're welcome. ;)
If you need more help, just ask. Otherwise, you should click on the blue button and it will mark this question as "answered" on the main page.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
