loading
No Bitmap folder?
When I go to ADD-INS > Scripts and Add-Ins... I select Image2Surface from the list and click Run and it does not open a folder with Bitmap images in it, why?
The next step says"The script opens a window where you can choose a bitmap image". But it doesn't.
JON-A-TRON2 months ago
It sounds to me like the script didn't install properly. I would suggest removing it (right-click > Remove), then carefully following the instructions for installing again. If that doesn't work, I would check this thread on the Autodesk Knowledge Network: https://knowledge.autodesk.com/support/fusion-360...
