OST File Not Fixed With Scanpst.exe Inbox Repair Tool?
I am trying to recover an OST file that is about 4GB in size.  When the scanpst.exe program is running, it makes it through 7 of the 8 steps and then throws the following error message:
An error has occurred which caused scan to be stopped. No changes have been made to the scanned file.
Is there anything I can do to recover this corrupted OST file?
markbro3772 years ago
I would say verify that the items listed here are not true
http://community.office365.com/en-us/f/158/t/266518.aspx
Otherwise I have not found any good solution other than just rebuild the ost file.
JamBrat2 months ago
The scanpst.exe utility is used to repair PST file. But to repair OST file, you need to use the Integrity check tool, commonly known as scanost.exe utility. It's a built-in repair tool is MS Outlook that can scan corrupt OST file and repair it.
Refer to this blog post to know more about scanost.exe utility and how to use it - http://wordpress.semnaitik.com/2013/10/29/repair-o...
jamminarpo2 months ago
If you are unable to recover corrupted OST file by using scanpst.exe then you should download OST recovery tool from https://www.mailvare.com/free-ost-repair/
This is a free tool that helps to recover mailbox items from OST file and convert into PST file format.
mishaalter2008 months ago
Obtain MaxiaSoft OST to PST converter Software that greatly
works for recovery data of Outlook OST file
and again open OST file into PST file, EML, MSG and HTML formats by split
recovered heavy PST file to small PST file (1GB upto 5GB). This Software is
perfect solution to recover corrupted OST file and transfer OST file into small
PST file safely.
Get More Details This Tool-: http://www.ostrecovery.biz/
MaritzaB210 months ago
After the failure of Scanpst.exe many users prefer third party tool for recovering OST file data so I would like to share another stunning software for OST file recovery & conversion. This tool has many features which helps users to overcome this type of problem. Practical is better than the words so you should try this tool at your end from this web link: http://www.magicsoftrecovery.com/ost-recovery.html
bhojamrita1 year ago
You need Mail Converters for OST to PST. It is one of the best and advanced software, which can easily convert your exchange OST to PST without any hassle and take very less time to convert. To download this Best OST to PST Software, visit: http://www.mailconverters.com/ost-to-pst.html
AlishaA91 year ago
OST Recovery Tool is required when you want to convert your OST email files into the format of PST email file. This tool is extremely effective and performs and provide quick results. http://www.purchase-software.org/converter/ost-to-pst.html
Repair OST files and then restore to the desired location by use this Regain OST to PST Converter which can repair whole OST file data and re-open OST file into new running PST, EML, MSG and HTML formats. It also recover OST file data along with whole corrupted Outlook OST email items such as - Inbox, outbox, sent mail, note, task, journals and draft etc.
For more info :- http://www.convertostintopstfile.com
KyleM391 year ago
OST recovery tool that easily recovers entire Outlook
mailbox data including emails, attachments, contacts, notes, tasks etc. from
corrupt or damaged OST files and converts them to Outlook accessible PST
format. - See more at: http://www.mozesoft.com/ost-recovery.html
I don't know this question answer but we providing gmail technical support to know more https://www.e-mailtechnicalsupport.com/
JamesP3621 year ago
You can use OST to PST Converter which can easily convert whole Outlook OST file versions and save OST mailbox as new PST without any harm.
http://www.osttopstconverter.edbtopst-converter.com/
Fully professional program to convert damaged OST file to MS Outlook PST format. It can also repair and restore corrupt OST data into Outlook PST file format.It also smoothly recover unreadable OST file and convert OST into PST file format with all OST file emails Meta data like: cc, bcc, to, from, date, time and subject etc.Check out http://www.recoverfilesdownload.com/ost-recovery-tool.html
You
can easily recover data from damaged or corrupted OST file within few
minutes. In last month I also faced the same problem and at that time I
utilized Microsoft OST to PST converter. Try it's demo version.
karla31 year ago
Here is another advanced solution available at http://www.osttopstconverter-tool.com/, this software Smartly re-access your all data from corrupt OST file and convert OST file to PST format. This software also helps to provide convert OST file data into PST, EML, MSG and HTML formats within all OST file folders and mails properties.
You can use OST to PST converter technique which can also useful to fix corruption issue from OST file of Exchange Server. I would like to request try to fix inaccessible issue of OST file through the link: http://recoveryandmanagement.com/2014/08/26/repair-ost-and-convert-into-pst-outlook/
I have faced the similar problem like yours and tried OST Repair software suggested by one of my friends. Tool works fast for repairing majorly corrupted ost file of any size. It is designed to convert OST to PST by keeping secure all original parts of OST email. One important fact using this software is that it is available in its free trial run. see more details here ; http://www.ostpstsoftware.com/
Scanpst.exe utility will not work if ost file is majorly corrupted. There might chance to loss some important details as during the process of repairing OST file it produces healthy ost file but removes corrupted parts also. Hence it is recommended to use good OST to PST software to recover corrupted ost file.
FerihaJ1 year ago
If your OST file is corrupted and your Exchange account is active then you can make your OST file healthier just by recreating of OST file. You need to go through the following procedure;
1) Choose the ost file have to rename
2) Right click on it
3) Change the extension from .ost to .ost.old and press enter
4) Now access your Exchange Server account and open Outlook
5) MS Outlook will reconfigure the data file and the new ost file will not be corrupted
But one drawback using this procedure is that during the process of repairing OST file it will also remove corrupted parts of OST file and create a new healthy ost file. Hence if data is your primary concern then you should pic reliable software here;
http://www.solutions.microsoftostconverter.com/ost-to-pst-converter/
I tried an easy to use solution to shift my OST file data to PST format. You may also download this good OST to PST conversion software from a trusted shareware website: http://www.tucows.com/preview/1603422/MailsDaddy-OST-To-PST-Converter
RexT21 year ago
Use OST to PST Converter software which is an effective solution to read OST file data and convert all OST emails into new PST, EML,MSG and HTML file format.. It is assured utility which keeps data safe & restore OST in PST, MSG and EML along with its attachments and Meta details. It is relevant for emails, task, notes, to do list, contacts, calendar etc. See more info visit :-
http://www.tools4recovery.com/ost-to-pst-converter.html
RudyC111 year ago
Smart solution and realible method to convert corrupt Outlook OST files into PST format with the help of :- http://www.osttopstconverter-tool.com/
StivenM11 year ago
For Repairing OST file you can use Integrity Check Tool (Scanost.exe). The tool scan damaged OST file and recover mailbox data of file. The scan log file also consists of information that the tool cannot repair. You can easily find the log file in Deleted items folder. To execute Scanost.exe utility to need to connect exchange account.
See more details about this utility, here:- https://sonikarawat.wordpress.com/2014/09/11/repair-ost-file/
EricS2351 year ago
ScanPST is specially designed to repair PST file, not OST file! Of course we have seen few scenarios where Inbox repair tool does the job appropriately and repair the file from some error but it doesn't mean it is the guaranteed solution for corrupt OST file.
Source: http://www.stellarservertools.com/blog/convert-ost...
And as per your query, whether you attempt to repair an OST file or PST file, Scanpst.exe (inbox repair tool) does not repair Outlook data file bigger than 2 GB.
Kaye R.J1 year ago
Unfortunately, SCANOST.EXE is not much powerful to offer you the best result as you need. In such situation, you need third-party http://www.osttopstconverter.recoverydeletedfiles.com that can repair and recovers corrupt, damaged, infected, lost, or deleted OST file with all email properties also such as To, From, Subject, CC, BCC, and Date.Also provide various options to save repaired OST file like PST/HTML/MSG/RTF/TXT/EML file format.
You can go with Kernel for OST to PST converter, this is an advanced
solution for Outlook users. Using this tool you can fix all corruption
issues from MS Outlook OST files and convert them to Outlook PST file
format with all attachment. To know more and download this tool visit
here:- http://www.nucleusdatarecovery.org/convert-ost-to-pst.html
KyleM391 year ago
OST to PST Converter tool to recover all recover OST emails from the affected file. OST database recovery tool even convert OST emails to PST & open OST to PST/EML/MSG/HTML. - See more at: https://softcart.wordpress.com/ost-to-pst-converter/ or http://www.mozesoft.com/ost-to-pst-converter.html
I would suggest Ost Recovery software that naturally repair damage OST file and recover whole OST data into well file format. Through this software slickly solve OST file conversion problem and get new readable four different file format such as- PST/MSG/EML or HTML file format.
More Info – http://www.filesrecoverytool.com/ost-recovery.html
JosephB722 years ago
Most effective and reliable OST to PST Converter Software to recover OST file data along with whole corrupted Outlook OST email items such as - Inbox, outbox, sent mail, note, task, journals and draft etc. By using this application, you can also move recovered OST file into several formats like – PST, HTML, MSG and EML successfully. For more detail visit here :- http://www.mannatsoftware.com/kernel-ost-to-pst-converter.html
Markm312 years ago
To repair and recover damaged or
inaccessible Outlook OST file, you can get a help of Kernel for OST to
PST conversion software that allows you to repair and restore corrupt
Outlook OST file to accessible PST format without altering nay data. For
more visit
http://www.osttopstconvert.recoveryfiles.org/ or
http://www.osttopsttools.org/
BlakeMarky2 years ago
Look at this professional RecoveryFix OST to PST is the best tool to recover OST file and Convert outlook OST to PST, EML, MSG and HTML formaty. The Software easily Convert OST to PST and gives the option to split oversized files into Small PST in less time. For any information visit here: http://www.osttopstfile.net/ and http://www.outlookost.org/
JackCa32 years ago
Try exchange OST to outlook PST Converter software which can fix OST file corruption issue and save OST database into Outlook PST/EML/MSG/MBOX/DBX/PDF and HTML along with every mails properties such as emails headers and email information etc. To simply resolve out and export OST file into Outlook with complete attachments- embedded images, journals, tasks, remainders and notes etc.
Read more : - http://www.osttopstfree.com/
Poonam12 years ago
Why you have used the SCANPST.EXE program to repair your corrupted OST files?
Instead of this use the SCANOST.EXE ( Integrity check tool) to repair your corrupted OST files. Or, if the OST files will not repair with the above tool then use any OST recovery tool. Check the full information about SCANOST.EXE
http://wordpress.semnaitik.com/2013/10/29/repair-ost-file/
Yes you can recover your corrupt OST file with this OST file Repair tool. This tool repair your damaged OST file and convert into Outlook PST file format without any data lose. You can visit this web to know more detail and free to download the demo version of this tool: http://bit.ly/1jycYmZ
DonnaA172 years ago
This issue will be fix soon using advanced OST
file recover that is apt to fix OST corrupt from database. Tool supports all Windows OS, MS Outlook and works well
Visit- http://www.ostrepair.net/
